Author Topic: body change  (Read 13159 times)
Offline sameold
body change
« on: July 22, 2014, 06:10:45 pm »
Hey Guys I am a newbie here but born and raised GM my whole life.
I have a late 1979 chevy K30 350 400 trans 4wd NP205.
I am changing the body soon and have a couple question and will just present them and maybe you can answer. The donor body is a 85 2wd and I know I need to transfer over the windshield wiper linkage. Any info would be great!!
Obviously, I need to cut an access panel for the 4wd linkage on the floor.
Do I need to cut a bigger hump? Can I install a body lift kit to clear the np205?
The 79 has a very primitive dash and dash pad. Will it transfer over?
Anything else please let me know .
Offline roundhouse
body change
« Reply #1 on: July 22, 2014, 08:33:08 pm »
I dont think the dash pad will work on a newer cab
You will have to use a 81 up pad
If your k30 has a removable hump it should transfer over
Dont think you will need a body lift
« Last Edit: July 22, 2014, 08:44:39 pm by roundhouse »
Offline sameold
Re: body change
« Reply #2 on: July 23, 2014, 06:28:48 am »
I don't have a removable hump. Can I just cut a little access hole for the 4x4 shift levers like in the old cab?
Re: body change
« Reply #3 on: July 23, 2014, 07:56:47 am »
     Here are some threads that should answer your questions and be some good reading materials.
     Cab swap:  http://forum.73-87chevytrucks.com/smforum/index.php?topic=27782.msg231272#new
     Windshield wiper linkage:  http://forum.73-87chevytrucks.com/smforum/index.php?topic=9070.0
     Trans hump:  http://forum.73-87chevytrucks.com/smforum/index.php?topic=11838.0
Offline roundhouse
Re: body change
« Reply #4 on: July 25, 2014, 11:53:37 am »
That should work fine
You could also cut the hump out of the rusty old cab and use it
Offline pholliday1
  • 1990 V3500 Crew Cab
Re: body change
« Reply #5 on: July 25, 2014, 12:21:51 pm »
Sometimes putting in a simple body lift takes care of the hump issue.
Offline BADAZ chevy guy
  • Chevy! My drug of choice!
Re: body change
« Reply #6 on: July 25, 2014, 02:48:26 pm »
Just curious. Are you going to register it as an 85 or a 79? You're going to have different VIN numbers on the cab and on the frame.
Offline roundhouse
Re: body change
« Reply #7 on: July 25, 2014, 10:27:27 pm »
Meh.   Just swap the VIN plate on the dash
Keep the existing one and put it on the new cab
You will be the only person that knows
Re: body change
« Reply #8 on: July 26, 2014, 10:16:23 am »
Yup, Yellow Snow is and 83 C10 cab, it is registered as an 86 K2500 as thats what the VIN plate on the dash says it is. Came off the old cab
Offline sameold
Re: body change
« Reply #9 on: July 26, 2014, 06:52:42 pm »
thanks a lot! You have a nice forum here and I will need some help .
I am going to swap the plate and get rivets on ebay.
Offline sameold
Re: body change
« Reply #10 on: July 26, 2014, 06:58:50 pm »
body mount  bushings.
I have get bushings for the frame . Its a late 79 and the rear upper mount had a sleeve that went thru the old bushing. The sleeve was rotted away and more or less destroyed. What would you guys suggest?
http://www.ebay.com/itm/Prothane-73-80-Chevy-GMC-2WD-4WD-Regular-Cab-Body-Mount-Bushing-Kit-1-2T-3-4T-1T-/271391548136?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1979%7CMake%3AChevrolet%7CModel%3AK30&hash=item3f303262e8&vxp=mtr
I was going to get this bushing kit. Can I cut the sleeve flush and weld on a new sleeve?
Does this new mount kit bypass the sleeve or can I use a smaller bolt?
Re: body change
« Reply #11 on: July 26, 2014, 09:00:47 pm »
I have welded a new tube onto the top bushing plate in the past.
Offline roundhouse
Re: body change
« Reply #12 on: July 27, 2014, 02:51:10 pm »
Also hockey pucks make a
Inexpensive 1" body lift
Lot cheaper than buying a body lift
Offline sameold
Re: body change
« Reply #13 on: July 27, 2014, 04:11:50 pm »
whats the chance of the np205 and 400 trans clearing the tunnel? Would I be able to shim the rear cross member down slightly? The fit looks close on the new cab going on and I am not sure if the 400 trans and 205 case will clear.
Re: body change
« Reply #14 on: July 27, 2014, 06:34:13 pm »
     The 85 cab, does it have a small hump or big hump ?  Did you see the thread on the differences in hump styles ?
