Author Topic: 1979 K30  (Read 5181 times)
Offline sameold
1979 K30
« on: July 26, 2014, 07:02:48 am »
Taking the cab off and swapping with another cab. The rear body bolts have broken the spot welds for the nut inside the cab. Any ideas? I was going to fold own the back seat and cut a hole to see if I can access the buts and secure them.
Offline square81
Re: 1979 K30
« Reply #1 on: July 26, 2014, 07:15:00 am »
I have done that and it worked. Then when I was finished just welded the access hole back up, cleaned up the area and painted it. Never knew I was there.
Offline zheier
Re: 1979 K30
« Reply #2 on: July 26, 2014, 07:54:25 am »
did the same thing but put access panels over the holes so i could get to them again if need be
Re: 1979 K30
« Reply #3 on: July 26, 2014, 10:20:07 am »
I use a hole saw, then make a cover & rivet them in place. Then if you need to gain access again, simple as drilling out a few rivets.
Offline Boonie
Re: 1979 K30
« Reply #4 on: July 26, 2014, 04:25:27 pm »
i used a hole saw on my old 84, then just put rubber expansion plugs in them.  worked great
Offline sameold
Re: 1979 K30
« Reply #5 on: July 27, 2014, 06:51:14 am »
worked out well. I had to heat them up up mapp gas and while the bolts cooled I sprayed them with wd40.
