Author Topic: Steering Noise  (Read 5577 times)
Offline Skinner
  • 1974 LWB
Steering Noise
« on: July 30, 2014, 10:06:40 pm »
1974 2wd, 350, no A.C.  I've notice a rubbing noise when I turn the steering wheel to the right.  The noise happens while sitting still and while driving.  Very consistent tempo almost like a pulley rubbing something.  I do not feel anything in the steering wheel.  I checked the dust shield by the brakes and all the pulleys are tight.  Any ideas?  Thanks in advance.
Re: Steering Noise
« Reply #1 on: July 31, 2014, 07:51:05 am »
Have someone sit behind the wheel while you observe the power steering pump during the rubbing sound.
Re: Steering Noise
« Reply #2 on: July 31, 2014, 08:58:34 pm »
     Check all the front of the engine bay and underside of the truck when the noise happens.
Re: Steering Noise
« Reply #3 on: July 31, 2014, 09:02:59 pm »
Your pitman arm to centerlink joint when dry makes a creaking noise some times and popping noise at other times
Offline Skinner
  • 1974 LWB
Re: Steering Noise
« Reply #4 on: August 01, 2014, 05:02:53 am »
Checked everything I can think of.  All looks normal.  I believe I may need to change the pump out. : (    Thanks for the replies.  I'll let you know if the pump fixes it.
Re: Steering Noise
« Reply #5 on: August 01, 2014, 12:49:59 pm »
If you replace the pump, be sure to completely flush the system with fresh fluid.  Fill with GM spec power steering fluid or full synthetic p/s fluid rather than ATF.  Avoid fluids with stop leak.
Offline Skinner
  • 1974 LWB
Re: Steering Noise
« Reply #6 on: August 08, 2014, 06:00:20 am »
It was the pump. Thanks for all the suggestions.
Re: Steering Noise
« Reply #7 on: August 08, 2014, 07:40:00 pm »
     Glad to hear you figured it out and got it fixed.
