Author Topic: flip kit installed  (Read 5226 times)
Offline jaime
flip kit installed
« on: August 01, 2014, 12:57:05 am »
So I just install flip kit but I took measurement and im a quarter inch of one side  one wheel is closer to edge of  of the rear bed fender how can I fix this with out  basically taking everything apart
Re: flip kit installed
« Reply #1 on: August 01, 2014, 07:17:42 am »
     Please tell us how you measured, from what points to what points.  Then somebody can give you idea's.
Offline jaime
« Reply #2 on: August 01, 2014, 11:22:46 pm »
I measured from the chassis to the back of drum
« Reply #3 on: August 17, 2014, 02:06:50 pm »
There is no adjustment in the axle. If you want the bed to match you will need to move it...  but give that it is 1/4" can you be sure you measure from the same spot?  The flip kit didn't do this, so did you measure prior?
Offline jaime
« Reply #4 on: August 22, 2014, 12:09:07 am »
No I didnt measure prior but when I bought t the truck one of the rear tires did have a spacer  which is a querter of an inch thick
