700R4 leak
Topic: 700R4 leak (Read 17994 times)
swilliams
700R4 leak
August 02, 2014, 10:06:57 pm »
I have a stock 700r4 that has started leaking from what i assume is the front seal. It does not happen all the time just when ever it wants to but when it does it leaks about a half a quart or more. I have jacked up the truck looking for the leak (have not removed the fly wheel cover yet because i have to remove part of the exhaust to do so) there are no obvious signs of a leak. The only place I figure it can be coming from is the hole in the dust cover. Has anyone herd of this.
Re: 700R4 leak
August 02, 2014, 10:24:34 pm »
when your moving wind can push fluid all around. so best thing to do is clean it all up and check for leaks. could be something simple like the o ring on the filler tube or a bad pan gasket and the vent tube can leak
swilliams
Re: 700R4 leak
August 02, 2014, 10:45:55 pm »
I have helped my stepson with the vent tube on his 2004 Taurus. His leaked out 2 and a half quarts. The under side of my trans has no fluid leaked on it. I recently had to replace the TV cable so i thought that would be it but nothing on or around it or the pan bolts i only have a few drops on my exhaust. This is the 3 time since the problem started that it has leaked about 2 months time. I cant be sure but the signs point to that it only leaks when it is sitting but like i said it does not happen all the time. Very strange to me. I have put cardboard down to try and see where it is leaking had it down for 2 weeks no leaks i cleaned and swept the garage and did not put it back down and what do you know it leaked and ran to one side so i tried to see anything but found nothing. I am going to have to pull the dust cove to check.
Rich84
Re: 700R4 leak
August 04, 2014, 12:12:48 pm »
Mine did the same thing after sitting for a couple of weeks. It was leaking out the weep hole in the yoke.
swilliams
Re: 700R4 leak
August 04, 2014, 12:18:07 pm »
Did u do anything for it
Rich84
Re: 700R4 leak
August 05, 2014, 08:13:09 am »
A little rtv in the hole did the trick..
Re: 700R4 leak
August 05, 2014, 10:59:03 pm »
with the yoke problem you will see oil sprayed up on the bed right above the yoke. rtv is a quick fix but i think inorder to fix it proper you have to remove the tail shaft housing
Re: 700R4 leak
August 05, 2014, 11:09:02 pm »
http://www.73-87.com/7387garage/drivetrain/yokeleak.htm
swilliams
Re: 700R4 leak
August 19, 2014, 01:55:51 pm »
I have let my truck sit for 7 days. I was able to check on it the first 3 days with no leaks. The next 3 days did not check. Checked it today and found this....
Someone suggested that it might be an overheating issue because before i installed my headers it did not happen but no leaks in first 3 days and...
tranny fluid does not seem to be burned or discolored. Anyone have any ideas
LTZ C20
Re: 700R4 leak
August 19, 2014, 02:05:43 pm »
So it was just sitting for 3 days, not driven and leaked out all that?
LTZ Cheyenne C20
bd
Re: 700R4 leak
August 19, 2014, 02:15:00 pm »
So, you have a static leak. Use a flashlight and mirror to locate the highest point that is wet with ATF - fluid runs downhill. Don't start it or drive it, just look for fluid traces around the fill pipe and TV cable seals, servo cover seal, governor cover, speedometer adapter, output shaft seal, front pump & seal, vent tube, shift shaft seal, etc. That is a lot of fluid for just a few days. Since the vehicle hasn't been moved, the only thing moving the fluid around is gravity.
swilliams
Re: 700R4 leak
August 19, 2014, 02:24:07 pm »
i recently had to change the TV cable. I cleaned around it real good and have not really found any fluid there. As you can see from the trail my garage floor drains back and to the left so for the fluid to get to the front of the tranny i would think it is a front seal. I just have not had the time to remove the exhaust crossover that covers the dust cover to be able to check it. I dont understand why it takes so long to start leaking.
bd
Re: 700R4 leak
August 19, 2014, 03:38:54 pm »
Can you unbolt the cover and shift it around enough w/o removing the crossover to use a small articulated mirror and penlight?
swilliams
Re: 700R4 leak
August 19, 2014, 03:50:43 pm »
i am going to have this weekend off so even if i have to remove the crossover i have to find out. if it is the front seal what will it take to replace it.
bd
Re: 700R4 leak
August 19, 2014, 04:48:52 pm »
If you determine the front seal is the source of the leak the trans will need to come out for repair, because you will need to remove the converter for access. Once the converter is out of the way, replacing the front pump seal is similar to replacing a timing cover seal or trans output shaft seal; a steel shaft and the stator support protrude up through the center of the seal. The pump seal is installed and retained with red Loctite and caged by a steel retainer ring. However, if the front seal is causing that much of a leak, you may have a pump bushing that is wiped or shifted forward, or a restricted drain hole behind the seal.
Obviously, the first thing to do is accurately identify the source of the leak.
700R4 leak
