Author Topic: Ford fails yet again......  (Read 9438 times)
Offline Engineer
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline 74 C-10 Shorty
Re: Ford fails yet again......
« Reply #1 on: August 04, 2014, 10:50:12 pm »
I remember a while back seeing a Mercedes on I10 in LA looking just like that, the owner was sitting on the guard rail not a very happy camper, LOL... ;D
Offline LTZ C20
« Reply #2 on: August 05, 2014, 12:50:35 am »
FORD: failing since 1903. :D
LTZ Cheyenne C20
« Reply #3 on: August 05, 2014, 08:47:42 pm »
     Ford has some great vehicles, but for their flagship truck to have an aluminum body, I can see a lot of truck replacements in the future.
« Reply #4 on: August 05, 2014, 11:20:52 pm »
i dont know whats worse aluminum and salt or steel and salt
Offline LTZ C20
« Reply #5 on: August 06, 2014, 12:47:40 am »
Clearly aluminum and ford was not a good idea.
LTZ Cheyenne C20
Offline Engineer
« Reply #6 on: August 06, 2014, 06:38:48 am »
I'm not against the aluminum body idea. But until the body shops are equipped and trained, fixing these will be expensive. A problem that will fix itself over time.
I just think it is appalling that every time there is a Ford story it usually involves fire.
It seems on our local news atleast, when there is a house fire there will be a Ford truck smoldering in the ashes of the garage!?!?!......
Offline roundhouse
« Reply #7 on: August 06, 2014, 01:18:15 pm »
Any 10th grade science student can tell you what happens when dissimilar metals contact each other
For several years ford used an aluminium body fuel pump relay bolted to the steel frame on 150s and expys
THe resulting corrosion destroys the aluminium
How many places on the  body do they have steel bolted to aluminium ?
Offline pholliday1
  • 1990 V3500 Crew Cab
« Reply #8 on: August 06, 2014, 03:33:40 pm »
Land rover has done the aluminum thing for years, Humvees have an aluminum body but a standard everyday truck? I'm really skeptical. I just saw an aluminum 2015 F150 King Ranch and while it looked impressive I'm just not on board yet with that material.
Offline bladerunner
« Reply #9 on: August 06, 2014, 08:06:13 pm »
Well I would still drive a Ford over a foreign car any day. Or a Dodge, I mean Fiat...
85 K10 Shortbed
94 Impala SS
« Reply #10 on: August 06, 2014, 11:00:24 pm »
http://www.designnews.com/document.asp?doc_id=271215
Ford also uses a high-strength, dual-phase steel alloy for about 80 percent of the truck’s frame. The high-strength steel, which has a yield strength of more than 70 ksi, enabled Ford engineers to cut about 60 lb from the frame. Together, the aluminum alloys and the high-strength steel combined to eliminate about 700 lb from the overall vehicle weight. An F-150 4 x 4 crew cab, for example, drops from about 5,500 lb to about 4,800 lb.
so thats 700 more lbs you can haul
