Author Topic: How many leaf springs do you have?  (Read 6530 times)
Offline Stewart G Griffin
« on: August 16, 2014, 10:11:24 am »
i am just curious to know how many individual leafs you have?   i have the "G50 Heavy Duty Rear Springs" option and i have 5 leafs per side.
Offline fitz
Re: How many leaf springs do you have?
« Reply #1 on: August 16, 2014, 05:46:29 pm »
My 84 M1028 has 9 leafs in the spring pack + 1 overload spring.
The Military rated it at 5/4 ton with a 9400 pound GVW.
« Reply #2 on: August 17, 2014, 12:11:57 pm »
This is going to depend on the year, type of suspension (STD vs HD) and Series of truck and bodystyle..  So you are going to have answers all over the place.
« Reply #3 on: August 17, 2014, 03:50:57 pm »
Right, that's why i was curious.  i've driven other 1/2 tons and the ride was really cushy, well certainly more cushy than mine.
« Reply #4 on: August 17, 2014, 07:52:06 pm »
HD springs are going to ride much rougher than std.
Standard typically has 3 leafs.
Offline Da67goatman
  • Burban
« Reply #5 on: August 18, 2014, 02:03:12 am »
On topic, how few leaves do I need to reliably locate the axle?  I was thinking 2 possibly 3 to locate but I would be really excited to hear one leave is enough.
<Pitcrew>
Offline fitz
« Reply #6 on: August 18, 2014, 06:30:18 am »
My 69 Camaro still has the factory mono leaf rear suspension (the 10 bolt axle was swapped for a Dana 60 in the late 70's).
« Reply #7 on: August 18, 2014, 07:17:13 am »
Da67goatman, you will not be able to get by with just one leave there will be no stability of the rearend.
On a 3 leaf setup don't remove more than one, on a 5 don't remove more than 2.  This does not count the overload, you can pull it out immediately, but IF you pull leafs don't through it away as you may end up putting it back in.
