Author Topic: can I use a sbc 350 andtrany out of a 1990 truck in my 1985 k10  (Read 6506 times)
Offline derrik.kasinger
I have a 1985 Chevy Scottsdale k10 4x4 with a sbc 350 backed by a 700r4. the motor and tranny are shot in my truck .I am looking to swap both engine and tranny with a 1990 Chevy 1500. Can I do this????? And not have Any major problems. I am not sure I I want to use the tbi. If I decide to what all will I need to make it work? Please help all and any info will be nice
Offline fitz
Re: can I use a sbc 350 andtrany out of a 1990 truck in my 1985 k10
« Reply #1 on: August 18, 2014, 08:59:08 am »
What motor & trans are in the 1990 1500?
« Reply #2 on: August 18, 2014, 09:01:12 am »
The motor is a 350 and I believe its a stock 700r4 in the 1990. As far as we know ots all stock.
Offline thefarmboy21
« Reply #3 on: August 18, 2014, 10:12:20 am »
Should be able to swap them no problem, aside from swapping out a few sensors etc.....however the centerbolt heads require a different intake if you want to use a Carburetor. The center intake bolts go in at a different angle.
AMSOIL DEALER # 5583011
86 Chevy K20 Custom Deluxe-Grandpa bought it new 11/20/85
77 Chevy K10 Custom Deluxe-Dad's first truck
69 Chevy C30 flatbed-Grandpa's farm truck
1950 International L-112-Grandpa bought it new, parked in 1963
« Reply #4 on: August 18, 2014, 10:14:57 am »
Ok thanks so I couldnt use my intake for a carb swap? The motor mounts and all hookuos will work the same. What do I need to use the tbi if I wanted to
Offline fitz
« Reply #5 on: August 18, 2014, 10:21:50 am »
The 1990 block may not have the fuel pump boss cast into the block. If you decide to use a carb you may end up installing an inline electric fuel pump.
« Reply #6 on: August 18, 2014, 10:36:03 am »
Ok I believe im just goin to keep to with the tbi. Prbally goin to be easier.
Offline fitz
« Reply #7 on: August 18, 2014, 01:02:06 pm »
While TBI certainly has its advantages over a carb, I can't see it being "easier". Lots of wiring & fuel systems modifications to be done. Dont get me wrong, I'm a big fan of TBI motors, just have a solid game plan before you get started.
« Reply #8 on: August 18, 2014, 03:20:35 pm »
What dp ypu mean lots of wiring and fuel systems modifications?
Offline Zachary Halman
« Reply #9 on: August 18, 2014, 03:37:10 pm »
You can take the motor out of the 1990 truck and put it in your 85. Just take the intake manifold off your truck and put it on the new motor. I took a 1995 350 and put it in a 84 suburban the same way.
« Reply #10 on: August 18, 2014, 03:39:47 pm »
Ok sounds alot easier than trying to do alot of wiring and fuel system modifications. Is there anything else that might hold me up with this swap
Offline fitz
« Reply #11 on: August 18, 2014, 04:28:04 pm »
  As Farm boy pointed out,  your manifold off the 1985 motor will not just bolt onto the 1990 block. You will have to modify the 4 center bolts (2 on each side of the carb) to bolt up to the 1990 block.  You can buy an aluminum manifold that will bolt right on to the 1987+ blocks (center bolt valve covers)for about $200 ( just a guess). Other than the fuel pump I mentioned earlier, most parts will swap over. The 1990 motor is a 1 piece rear main block, so use the oil pan & flex plate off that motor.
  There is nothing wrong with keeping the TBI, just more work, and probably allot more $$.
« Reply #12 on: August 18, 2014, 04:36:02 pm »
Ok thanks I am buying a whole donor truck. So I will have everything I will need to do the swap. Including all tha fuel systems and everthing for the motor and tranny swap
