Author Topic: Transmission removal issue  (Read 4431 times)
Offline Dirka
« on: September 05, 2014, 07:59:48 pm »
Hey all,
I'm in the process of doing an engine swap in my 77 K10. The engine is out and I want to get the tranny checked out but I can't get the darn thing to come out!
I figured I could just pull it foward towards where the engine was and not have to remove any of the drive trains? All linkage, cables, bolts and mounting bolts have been removed, still no budge.  Do I need to take the crossmember off? Or maybe the tranny isn't at the right angle to slide forward?
Thanks,
Derik
Offline roundhouse
Re: Transmission removal issue
« Reply #1 on: September 05, 2014, 09:47:09 pm »
Probably a bolt still in it
What's holding the front of the trans up ?
Maybe put a jack under the trans and see if it's will lift off the cross member
I'd say you gotta drop the cross member to get the trans out
« Reply #2 on: September 06, 2014, 05:25:20 pm »
Is the transmission mount still in the crossmember?
Offline Dirka
« Reply #3 on: September 09, 2014, 10:50:37 pm »
I currently have a jack under the front of transmission holding it.
Both mounting bolts are removed and the 7 bolts that were bolting it to the transfer case. The mount itself (rubber piece) is still there.
Maybe I did miss one bolt?
Offline roundhouse
« Reply #4 on: September 10, 2014, 08:12:33 am »
I'd probably remove the transfer case first
Never seen anyone take out the trans while leaving the t case in
Offline Dirka
« Reply #5 on: September 12, 2014, 06:16:04 pm »
Thanks for the replies, i ended up getting another jack and taking both down together.
Ended up being I couldn't get the right leverage, laying under the truck, with a crow bar to separate them.  Once they were out they came apart easily.
But good side I get to degrease both and everything will be put back much cleaner and tidy than before!
Offline roundhouse
« Reply #6 on: September 12, 2014, 10:45:44 pm »
To make it easier to re install. Take the bolts holding he trans to the engine to a hardware store and buy some that are about twice as long
Cut the heads off.  And hacksaw a slot in the end where you cut the head off
Then screw these in (the slot is for a screwdriver )
Then you can slide the trans on and the headless bolts will support the weight.
Then you just swap the regular bolts back in one at a time
