Author Topic: 84 K10 shortbox lifted...looking to lower a couple inches and improve ride...  (Read 10216 times)
Offline 84Silverado4x4
I have an 84 chevy k10 shortbox that has a full spring lift front and rear that I'm guessing is around 8 inches of lift.  I would like to lower it a couple inches so that it will fit in my 7' garage door opening and a little better ride quality would be nice.  I am wondering if anyone has some suggestions on what the best set up would be for roughly a 6 inch lift or so would be and for a good all around truck that can handle towing a car trailer or load but still ride decent for an 84 chevy that's lifted.  I Like the lift and would like to keep my 35" tires but being able to fit in my garage and a better ride would sure be nice.
84 Silverado Reg Cab Shortbox 4x4
4" lift with 35's
5.3 vortec, 4l60e, np208, dana44, GM 12 bolt
     Super lift or skyjacker are some of the softest lifts.  Tuff country and ruff country are a lot harder riding lifts.  Rancho makes a medium lift as far as ride comfort.
Offline roundhouse
4" should be plenty for 35's
We have 33's with no lift and no rubbing at all
A 2" or 2 1/2 should clear 35's
     He likes the lift and was asking about 6" lifts.  He also did not mention if he ever planned on going off road with it, a 4" lift with 35"x12.5"x15 tires on a wide rim will rub if you articulate it too much, like going through ditches and such, or turning hard at off angles.
    It makes a big difference on rubbing on how wide the rim and tire are.  33" 35" tires can come in multiple widths, getting the right width or rim/tire and lift is important.
« Last Edit: September 13, 2014, 09:10:29 pm by bake74 »
Good point bake74... I use the truck more as a daily driver and it spends most its time on road however I would like to be able to take it off road and play once in a while...nothing too serious but you gotta have a little fun with a lifted truck.  The wheels are 18x10s and the tires are toyo mt's 35x12.50x18.
4" lift with 35's
     With those size tires and rims, I would not go anything under a 6" lift.
I had a 6" in mind.  Would anyone have an Idea about how tall that would put the cab so I know if I will be able to get in a standard 7' garage door with the 35's?  I don't know what my current lift is in the truck now however I did have another 84 shortbox with a 6" super lift in it and this trucks sits a good 2-3" taller than that one did...I measured the difference between the two at one time but I can't remember what it was exactly now.  My truck measures just under 7' 2" at the top of the cab with it's current lift and tire combo.  Like I said I like the lift but a few inches shorter to fit in the garage and a better ride would be nice.  No matter what I end up with for a lift I would like to keep it clearing the 35x12.50 tires to keep my gearing right.  The truck has overdrive so that helps but it has 4:56 gears and lockers front and rear.
4" lift with 35's
