Author Topic: Trash Container  (Read 9073 times)
Offline IdahoMan
Trash Container
« on: September 18, 2014, 06:22:22 pm »
What do you all use as a trash container for the interior of your trucks, and did our trucks ever come with such an accessory or the ability to accept one?
For example, my old 74 Impala Station Wagon had a removable trash container built in to the side/floor area on the passenger side ("kick-panel" I think it's called). When I look at the passenger side of my truck, it reminds me of that. What is that chrome piece BTW?
« Last Edit: September 18, 2014, 06:24:12 pm by IdahoMan »
Offline Elpresidente
Re: Trash Container
« Reply #1 on: September 18, 2014, 08:08:15 pm »
I open the slider window and then I've got an 8' trash container. I think that's all Chevy offered for our trucks.
The chrome piece is where the knob should be for the cab air vents. What it's doing there i'm not sure.
« Last Edit: September 18, 2014, 08:09:47 pm by Elpresidente »
'82 Chev Scottsdale
Proud to be Canadian \m/
Offline illinoisk30
Re: Trash Container
« Reply #2 on: September 18, 2014, 08:53:46 pm »
The chrome piece is a filler plug for the mentioned handle for the vent in the kick panel housing. Your ride has A/C so the valve is operated by a vacuum diaphragm for your recirculating air. Somebody will let you know if this is incorrect.
1977 Chevy K30 DRW 400 TH400
1978 GMC K35 SRW 454 TH400
1979 GMC K35 SRW 400 TH400
1980 Chevy K30 SRW 350 SM465
Offline FlatBlack77
Re: Trash Container
« Reply #3 on: September 18, 2014, 10:13:12 pm »
you got it right.
the first thing that comes to my mind when you ask about a trash container is the door pouches
id imagine you could make them easily removable with some hooks on the top holes and some velcro on the bottoms to keep them from flappin around when the doors need to be slammed closed
« Last Edit: September 18, 2014, 10:16:21 pm by FlatBlack77 »
Offline roger97338
Re: Trash Container
« Reply #4 on: September 20, 2014, 04:01:42 pm »
I forgot I wasn't on reddit for a moment, and was looking for the 'upvote' button.
The chrome piece replaces the knob on pickups equipped with air conditioning. Those vehicles don't have the manually opened floor vents.
For trash, I've this bag that I hang on the passenger side floor vent knob. It also doubles as a drink holder that I can't reach.
« Last Edit: September 20, 2014, 04:06:15 pm by roger97338 »
Offline IdahoMan
Re: Trash Container
« Reply #5 on: October 03, 2014, 12:31:01 pm »
Roger,
I see you have a fire extinguisher.
I'll be getting one of those too. How is yours attached?
Offline roger97338
Re: Trash Container
« Reply #6 on: October 07, 2014, 02:57:03 am »
Roger,
It used to be attached using the wall mount bracket that it came with. Over the years, being at an angle evidently took its toll on that bracket, because eventually it didn't hold the extinguisher anymore. (I don't remember what part of the bracket failed.) I found this bracket at a second-hand store. It seems to be just another type of wall-mount bracket, but this one has that piece that supports the bottom. The previous bracket didn't have that support; It held the neck, and the quick release band held the middle.
Still, the first bracket lasted fifteen years, so I'm not going to complain about that at all.
That location seems to be out of the way. I've rode on that side a few times, and I didn't notice it was there. It would mount upright behind the seat nicely too, if you didn't want a big red bottle uglying up your interior. Don't have one in the cab and not have it mounted, though. My boss did that, and it rolled under his seat. When he tried to move his seat and it didn't budge, he put some force into it, and broke it at the neck. The inside of his pickup was absolutely covered in that yellow powder!
Offline IdahoMan
Re: Trash Container
« Reply #7 on: October 08, 2014, 03:30:54 pm »
Thanks roger!
Looks good.
What do you have it screwed into? Looks like a custom piece of metal?
Offline roger97338
Re: Trash Container
« Reply #8 on: October 09, 2014, 11:12:25 am »
Thanks roger!
Looks good.
The panels were dented up, so I put a piece of tin over them in 1987. I intended it to be a temporary fix, until I could do a more professional looking repair.
