Author Topic: Box swap  (Read 3643 times)
Offline tonyb
Box swap
« on: September 23, 2014, 04:26:28 pm »
I have a 78 3/4 ton, the box floor is getting bad and I found a newer box at a good price. Question is I have dual tanks and the caps are round with no doors. The box I am looking at I am told is a 79 and it has dual square doors. Are the locations in the same spot and what would I have to do to make it work? Thanks.
Offline illinoisk30
Re: Box swap
« Reply #1 on: September 23, 2014, 07:28:35 pm »
The fuel doors are in the same spot as your bed with the round holes, as for the fuel necks you need to get the fuel necks for a 1979-82 Chevy/GMC truck. That would be the easiest. The necks are 79-82 specific and have two tabs coming off the neck that screw to the bed. I think someone sells the necks in whatever style you need per year of bed that you have. . You will also need the hoses. I have provided some pics of the correct necks. Have fun.
« Last Edit: October 09, 2014, 09:47:56 pm by Captkaos »
1977 Chevy K30 DRW 400 TH400
1978 GMC K35 SRW 454 TH400
1979 GMC K35 SRW 400 TH400
1980 Chevy K30 SRW 350 SM465
