Author Topic: 86 c10 water temp sensor  (Read 3607 times)
Offline pete.mccarthy1986
« on: September 24, 2014, 09:07:42 am »
I am trying to locate or identify the water temperature sensor that is located on the water outlet housing along with the ported vacuum switch.  I am assuming its a sending unit as It has a single prong.  Looking through part sites I can only find sensors with two wires.  Do I need to convert it to a two wire or is this just a hard to locate part?
Offline 78BIG-TEN
Re: 86 c10 water temp sensor
« Reply #1 on: September 24, 2014, 12:44:30 pm »
More info would help,but just guessing the switch in the t\stat housing is for egr bleed solenoid.Temp gauge sensor in left cylinder head ,assuming this is a 305 non ecm controlled system
« Reply #2 on: September 24, 2014, 02:30:25 pm »
Thanks I will post a picture when I get home.
« Reply #3 on: September 24, 2014, 07:09:51 pm »
I think its a temperature switch not a sensor.   The single wire runs to the accelerator pump solenoid.   Not sure yet if it activates the engine temp light or has some role in  activating the solenoid.  When I get it running this weekend I will know for sure (I hope).
« Reply #4 on: October 09, 2014, 09:36:16 pm »
Is this the part in the water outlet that houses the thremostat?
Offline 78BIG-TEN
« Reply #5 on: October 10, 2014, 10:00:22 am »
Yes t\stat under water outlet
« Reply #6 on: October 10, 2014, 09:14:23 pm »
That is part of the EFE and Air Injection Reactor system
