86 c10 water temp sensor
Topic: 86 c10 water temp sensor (Read 3606 times)
pete.mccarthy1986
September 24, 2014, 09:07:42 am »
I am trying to locate or identify the water temperature sensor that is located on the water outlet housing along with the ported vacuum switch. I am assuming its a sending unit as It has a single prong. Looking through part sites I can only find sensors with two wires. Do I need to convert it to a two wire or is this just a hard to locate part?
78BIG-TEN
Re: 86 c10 water temp sensor
September 24, 2014, 12:44:30 pm »
More info would help,but just guessing the switch in the t\stat housing is for egr bleed solenoid.Temp gauge sensor in left cylinder head ,assuming this is a 305 non ecm controlled system
pete.mccarthy1986
September 24, 2014, 02:30:25 pm »
Thanks I will post a picture when I get home.
pete.mccarthy1986
September 24, 2014, 07:09:51 pm »
I think its a temperature switch not a sensor. The single wire runs to the accelerator pump solenoid. Not sure yet if it activates the engine temp light or has some role in activating the solenoid. When I get it running this weekend I will know for sure (I hope).
October 09, 2014, 09:36:16 pm »
Is this the part in the water outlet that houses the thremostat?
78BIG-TEN
October 10, 2014, 10:00:22 am »
Yes t\stat under water outlet
October 10, 2014, 09:14:23 pm »
That is part of the EFE and Air Injection Reactor system
