Author Topic: Will 37" tires fit with a RC 4" lift on an 83 k20  (Read 7042 times)
Offline leelolunsford
« on: September 25, 2014, 10:39:23 am »
I found a great deal of military tires and wheels and have a 4" lift. My truck is more of a daily driver tow rig so no need to have a lot of flex. Does anyone have this setup? If so pics would be appreciated thanks!
Offline ehjorten
Re: Will 37" tires fit with a RC 4" lift on an 83 k20
« Reply #1 on: September 25, 2014, 04:46:37 pm »
I would say no!  You might get away with 35's but that would be it in my opinion.
-Erik-
Offline fitz
« Reply #2 on: September 25, 2014, 05:10:12 pm »
I'm thinking you would have to trim the front fenders to get them to fit.
How wide are the rims?
« Reply #3 on: September 25, 2014, 10:55:13 pm »
with 6" 38s should fit but you rub a little one bumps and turns
« Reply #4 on: September 27, 2014, 09:31:14 am »
       As fitz said, rim width makes a big difference, they might fit in the wheel well, but I wouldn't drive it around any corners or over any bumps.
Offline FlatBlack77
« Reply #5 on: September 27, 2014, 03:34:15 pm »
backspacing can be a factor too not just width
Offline frotosride
    • WFO CONCEPTS
« Reply #6 on: September 28, 2014, 07:07:23 pm »
I. Currently have 4" RC and am running 35x12.5 on old MT 15/10.5 wheels with no issues. The biggest concern is the width. Since they r military tires they may fit fine but the rear part of the front fenders is where you will run into an issue first. Swing by if you can pop one on the front and turn it lock to lock.. Problem solved
