Wheels & Tires
Will 37" tires fit with a RC 4" lift on an 83 k20
Topic: Will 37" tires fit with a RC 4" lift on an 83 k20 (Read 7043 times)
leelolunsford
New Users
September 25, 2014, 10:39:23 am »
I found a great deal of military tires and wheels and have a 4" lift. My truck is more of a daily driver tow rig so no need to have a lot of flex. Does anyone have this setup? If so pics would be appreciated thanks!
ehjorten
Re: Will 37" tires fit with a RC 4" lift on an 83 k20
September 25, 2014, 04:46:37 pm »
I would say no! You might get away with 35's but that would be it in my opinion.
-Erik-
fitz
September 25, 2014, 05:10:12 pm »
I'm thinking you would have to trim the front fenders to get them to fit.
How wide are the rims?
September 25, 2014, 10:55:13 pm »
with 6" 38s should fit but you rub a little one bumps and turns
bake74
September 27, 2014, 09:31:14 am »
As fitz said, rim width makes a big difference, they might fit in the wheel well, but I wouldn't drive it around any corners or over any bumps.
74 k10, 77k10 Tom
FlatBlack77
Cheap Fast Reliable - Pick 2
September 27, 2014, 03:34:15 pm »
backspacing can be a factor too not just width
frotosride
September 28, 2014, 07:07:23 pm »
I. Currently have 4" RC and am running 35x12.5 on old MT 15/10.5 wheels with no issues. The biggest concern is the width. Since they r military tires they may fit fine but the rear part of the front fenders is where you will run into an issue first. Swing by if you can pop one on the front and turn it lock to lock.. Problem solved
Wheels & Tires
