Author Topic: putting on a blower  (Read 7503 times)
Offline 78chev2bnice
putting on a blower
« on: July 22, 2005, 10:28:00 pm »
Is it really worth it to put a blower on my truck.  The motor is starting to use quite a bit of oil and I'm just going to pull the motor during the winter and rebuild it.  A supercharger is a good quick way to substantially increase horsepower but is it really worth it.   I would just go with a weiand 144 for now, because it is cheap and I've heard what the small blowers will do to a stock motor.
Offline aprice
re blower
« Reply #1 on: July 24, 2005, 12:40:00 am »
if your motor is getting weak, using oil, etc... i wouldnt recommened anything to get quick, easy power. a blower would be the death to your truck very quickly since it increases the compression ratio. thats what I think/know but i could be wrong. also i know you need better head gaskets otherwise you'll continue to blow them out
Offline roundedline
Re: re blower
« Reply #2 on: July 25, 2005, 02:11:00 pm »
Putting a blower on a worn engine that is using oil is a bad idea.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
blower
« Reply #3 on: July 27, 2005, 05:41:00 pm »
I was thinking of putting a blower on it in the spring after I rebuild it.
Offline roundedline
Re: blower
« Reply #4 on: July 28, 2005, 10:38:00 am »
In that case, yeah it is worth it.  I would build the motor for the supercharger application though.  No super wild cam profiles or high compression.
Project Su
Jimmy 2WD Project
blower
« Reply #5 on: July 29, 2005, 04:29:00 pm »
yeah thats what I figured.  I was going to go with pistons around 8.0.
Offline RSBAD454
Re: blower
« Reply #6 on: August 15, 2005, 11:18:00 pm »
A blower like the one you described is well worth it.....it adds almost 200 cubic inches of displacement. Like stated above, match components to blower.
Toys are my game
http://
Offline stepside454
blower
« Reply #7 on: September 22, 2005, 02:33:00 pm »
Im considering a Weiand 177 for my 454. gonna start on fresh body work & paint next month, trieing to figure what size cowl hood Ill need for room for the blower
Offline RSBAD454
Re: blower
« Reply #8 on: September 25, 2005, 02:59:00 pm »
I don't think you'll have a prob with a cowl hood. these trucks have a lot of room.
Toys are my game
http://
