Engine/Drivetrain
Diesel Engine Discussion
Cummins Swaps
(Moderator:
bajaburban
Crew Cab Cummins
Topic: Crew Cab Cummins (Read 43585 times)
LTZ C20
Re: Crew Cab Cummins
Reply #15 on:
November 09, 2014, 02:17:28 am »
Irish not sure what your asking here? How can I tell what ton they are by looking at axles and lug nuts? Usually lug nuts are the easiest giveaway, then the rear end and rear springs if you can get a quick peek at them, count the leafs. If it's a dually then it's obviously 1 ton or some kinda experiment lol.
LTZ Cheyenne C20
Reply #16 on:
November 09, 2014, 03:40:59 am »
lol i read you other comment and didnt understand what you were saying. but after reading your comment above that one i think i understand. you were saying crew cabs (being 3/4 or 1 ton) look better with long beds. while 1/2 tons (being regular cabs) look better with short beds
1HI4x4
V30 Crew now a shortbed.....
Reply #17 on:
November 09, 2014, 04:44:29 am »
For me it's all about the fact that GM didn't build a SWB Crew Square Body. Makes the conversation a little more interesting when you tell someone that you just cut it in half and welded it back together. In a small way it makes the truck seem a little more modern also.
1988 V30 Crew Cab, Cummins power, 47RH-NP205, 8" lift, 13.50x35x20 Fuel Mudders on 20x14 XD Diesels -76 offset. Soon to be repainted, seats from a 2010 Lariat to be installed.
1HI4x4
Reply #18 on:
November 09, 2014, 09:35:50 am »
Bumper gone, Reese Hitch gone, exhaust gone, 4" of the rear frame about to be gone.
1HI4x4
Reply #19 on:
November 09, 2014, 09:38:56 am »
Loosing weight, removed 4" and some misc brackets, on a 1 ton the passenger side shock has to be relocated, and I gave the brake lines a shot of WD40 as they look like an abortion on this truck so they need to be addressed later also.
1HI4x4
Reply #20 on:
November 09, 2014, 09:43:03 am »
Here's a picture of the Blazer tank all tacked in, I will remove it, install the rubber under the straps, and weld everything up solid when I weld the frame back together. Pretty good showing for a Sunday morning after feeding some bottle calves.............I'll eat myself a Pop-Tart and go back out and remove the saddle tanks.
LTZ C20
Reply #21 on:
November 09, 2014, 10:54:58 am »
Looks good so far. Yea Irish that's what I meant. Unless someone wants to take a crew 3/4 ton, chop the frame, slap a short bed on and through 1/2 suspension and axle under it. Lol. It would be a crew cab 1/2 ton.
LTZ Cheyenne C20
1HI4x4
Reply #22 on:
November 11, 2014, 06:02:25 am »
Here's a pic of the bed, fuel door relocated for the Blazer tank, body work all roughed in. Due to space limits in my shop I can only work on one side at a time.
Last Edit: November 14, 2014, 07:44:09 pm by VileZambonie
1HI4x4
Reply #23 on:
November 11, 2014, 04:43:18 pm »
That's some real amazing stuff, at home here on my Ipad the picture is upside down......when you click on it the picture shows larger and right side up.......at work this morning on my windows based laptop, it was upside down small and after you clicked on it.......obviously it's Bill Gates playing games from above.......
pholliday1
1990 V3500 Crew Cab
Reply #24 on:
November 11, 2014, 08:50:55 pm »
Picture is perfect on my iPhone
LTZ C20
Reply #25 on:
November 11, 2014, 08:56:03 pm »
Upside down on my galaxy s5 using tapatalk app.
LTZ Cheyenne C20
pholliday1
1990 V3500 Crew Cab
Reply #26 on:
November 12, 2014, 08:16:39 pm »
Shows a lot of skill on the relocation of the fuel door. Nice to see members with a lot of talent, keep up the good work !!
Reply #27 on:
November 12, 2014, 10:33:53 pm »
it was upside down on my computer. then i flipped my computer now its right side up
Reply #28 on:
November 14, 2014, 07:44:45 pm »
Fixed
LTZ C20
Reply #29 on:
November 14, 2014, 08:24:11 pm »
Hey that's better. Come do my body work please lol
LTZ Cheyenne C20
Engine/Drivetrain
Cummins Swaps
(Moderator:
bajaburban
Crew Cab Cummins
