Author Topic: 1975 Chevy Long Bed in California  (Read 5611 times)
Offline RipHughes
« on: November 08, 2014, 01:54:08 pm »
Hello!  Just acquired a 1975 Chevy Long bed in trade for a 2001 Honda Accord I used to have.  Its a working project so hopefully will be very useful to me as I slowly fix it up.  Currently has a strong inline 6 which I am debating keeping or upgrading to a bigger engine.
Previous Owner put a 1982 GMC front clip on it about 10 years ago.  Only real issues that I need to figure is the gas gage and tachometer do not work, hopefully this is a simple fuse problem.  Also apparently the aftermarket radio is draining the battery or the battery itself is not holding its charge.
I am a Novice to this site and a Novice to having a project vehicle so should be allot of hands on learning!
Steven V.
Hello.
Re: 1975 Chevy Long Bed in California
« Reply #1 on: November 08, 2014, 11:13:48 pm »
Welcome from NW Indiana.  The Tach cluster may have been added on by the previous owner and not wired in.  75 with a 6 cylinder would be rare having a tach but just cause I have never seen one doesn't mean they didn't exist...
Offline Dr_Snooz
« Reply #2 on: November 09, 2014, 11:20:05 am »
1975 is sooooo close being emissions exempt, but not quite there. Think carefully about the smog nazis as you plan your project. You don't want to spend a bundle only to find out you can't register it.
Offline RipHughes
« Reply #3 on: November 09, 2014, 02:37:32 pm »
1975 is smog exempt here in Cali 1976 is the first year they require it.
Hello.
Offline RipHughes
« Reply #4 on: November 09, 2014, 02:38:47 pm »
Showing just how much of a novice I am,  I meant to say Speedometer.  doh.
Hello.
Offline Dr_Snooz
« Reply #5 on: November 30, 2014, 06:13:44 pm »
Doh! You're right.
« Reply #6 on: December 01, 2014, 07:25:37 pm »
For the gas gauge check the post on how to test one in the Technical section.
For the speeedo, is the cable connected at the speedo gauge and the transmission?
