Brakes and Braking Systems
hydro boost issue
Topic: hydro boost issue (Read 6455 times)
duallydmax06
hydro boost issue
November 09, 2014, 03:08:13 pm »
Hello everyone, im working on a 84 gmc 1 ton crewcab dually 2wd with a 454 it has the hydro boost system on it and my problem is the other day the brake light came on and i lost power brakes the truck still stops you just have to press real hard now. The weird thing is the power steering still works great, acouple days ago i put some lucas power steering additive in for the leaky gear box that stuff slowed the leak down on my 85 so figured i try it on this one, anyone have a idea whats goin on here since the power steering still works?
2010 ccsb 4×4 duramax
1985 sclb k20
1979 sclb k20
1971 sclb c20
1928 model a coupe hot rod
zieg85
Re: hydro boost issue
November 09, 2014, 05:39:56 pm »
Those "fixes" swell rubber seals, OK for just power steering, probably not OK for the hydraboost unit...
duallydmax06
November 09, 2014, 10:44:33 pm »
It acted up the same day the lucas stuff went in you think it did damage to the hydroboost that quick?
1985 sclb k20
1979 sclb k20
1971 sclb c20
duallydmax06
November 10, 2014, 01:08:11 pm »
Anyone else have any ideas???
1985 sclb k20
1979 sclb k20
1971 sclb c20
bd
November 10, 2014, 01:31:59 pm »
Make sure the master cylinder is full of fluid, check the rear drum brake adjustment and inspect the calipers, rear wheel cylinders and all brake lines for leaks.
hydro boost issue
