Author Topic: 350 build for 83 k10  (Read 16711 times)
Offline Brocksdad1
« on: November 14, 2014, 08:11:40 pm »
Ok guys. I picked up this 83 that supposedly had a 350 😤 yea right.  Is say that the guy put in a gallon of motor hubby and prayed i bought it.
After it leaked and burned 1 1/2 quarts in 150 miles I decided a simple rebuild. Was in order.
Well that is not going to happen. After pulling the valve cover and actually digging the head bolts out of the sludge. It came to me that I had indeed a 305.
So I've lined up several 4 bolt engines to look at tomorrow.
And Ive been thinking of using vortec heads.
Tonight I found some bare aluminum vortec heads that are made for both style intakes and valve covers. On ebay. Has anyone seen these. Or used them?
They are set up for 202 160 valves. Screw in studs. Blah blah blah.
I already have a old performer intake and I just rebuilt a 1405 and put on a electric choke. So I have a bit of a start.
In wanting a nice driver with moderate power. I often pull a car hauler and very often pull a boat.
This will also be my daily.
Any and all input is appreciated
Bryce
Offline rich weyand
Re: 350 build for 83 k10
« Reply #1 on: November 14, 2014, 08:42:53 pm »
The bigger valves are good.  Vortec is good.
Cam it for torque, not horsepower.  You brag about horsepower, but you drive torque.
That'll help with towing, too.
Offline Brocksdad1
« Reply #2 on: November 14, 2014, 09:10:46 pm »
Have you seen these heads.
Offline Brocksdad1
« Reply #3 on: November 14, 2014, 09:30:46 pm »
Ok
Ive searched the net and here
Couple questions
Do i need vortec head bolts
Will my manifolds work
Will my 83 accessories bolt on
What cam for daily driver and pulling trailer
Anything Im missing
Bryce
Offline roundhouse
« Reply #4 on: November 14, 2014, 10:47:09 pm »
A lot cheaper to get a crate motor from the GM dealer
Or a good used vortec from a wrecked suburban
Goodrunning  used 350s are $500
Make sure you can hear it run before you buy
Offline Brocksdad1
« Reply #5 on: November 14, 2014, 10:48:47 pm »
I got screwed on this truck on a used old motor.
I want one that will last a long time not a year.
Thanks though.
Sent from my HTC One_M8 using Tapatalk
Offline rich weyand
« Reply #6 on: November 15, 2014, 01:05:41 am »
You can put a Comp 12-300-4 cam ($150) in a GM 350/260hp crate engine ($1500 delivered), and with a dual-plane manifold and headers get 420+ lbft of torque at 2500 rpm, which is a ton of grunt down where you can use it.  Not Vortec heads, but it's a brand-new engine with a 150,000 mile life expectancy.
Offline Brocksdad1
« Reply #7 on: November 15, 2014, 03:14:09 am »
Where are you looking these up. Maybe I'll look into it.
Thanks.
Just no engine from junkyard to the truck for me.
« Last Edit: November 15, 2014, 03:16:24 am by Brocksdad1 »
Offline 78BIG-TEN
« Reply #8 on: November 15, 2014, 10:10:19 am »
Vortec heads-Ehaust manifolds,head bolts,pushrods,accy's work.Valve covers,rocker arms,intake manifold need vortec type
Offline Brocksdad1
« Reply #9 on: November 15, 2014, 10:13:04 am »
How about this
1500 for everything computer wire harness everything.
Offline Brocksdad1
« Reply #10 on: November 15, 2014, 10:15:17 am »
How about this
Offline LTZ C20
« Reply #11 on: November 15, 2014, 11:16:00 am »
That engine can be pretty fun. Have one in my 91 camaro. That's in a vette tho, that's not a problem tho. There are a few companies that make performance kits and parts for that engine, including improved intakes, upper plenums and improved intake tubes (the 8 big tubes from the upper plenum to intake. Bigger throttle bodies and such are also available.
LTZ Cheyenne C20
Offline Brocksdad1
« Reply #12 on: November 15, 2014, 11:17:14 am »
I just wanted it for daily driver. So it will be fine as is as long as it will bolt in ok
Offline rich weyand
« Reply #13 on: November 15, 2014, 01:07:36 pm »
Thanks.
Summit, JEGS, Amazon.  I got that exact setup for mine from JEGS and I love it.
Offline Brocksdad1
« Reply #14 on: November 15, 2014, 01:55:55 pm »
Well I bought the engine. 1500.00
That is for everything
Accessories
A/C lines
Wire harness
Computer
OBD
EVERYTHING
I really don't think I got hurt. I ran the engine. Sounds great. And they are pulling it.
