Author Topic: Drive shaft /Trans Swap Question  (Read 8220 times)
Offline Gearheadmike
« on: November 19, 2014, 02:33:50 pm »
ok I have a 82 gmc serria c1500 2wd with v8 and th350 I would live to put a stud trans in it.
I have the 1 piece drive shaft also.
 Now I found a GM ST-10 Borg Warner 4 Speed on my local cl for $400 from a Impala now would that result in me needing a longer or shorter drive shaft?
Or if i find a 88-98 2wd 5 speed could I use that drive shaft?
Re: Drive shaft /Trans Swap Question
« Reply #1 on: November 19, 2014, 11:16:37 pm »
dont know about that trans but most time trans in cars wont work well in our trucks. think its something to do not just with the curb weight but its easier to load more junk into the truck than it is in a car
Offline roundhouse
« Reply #2 on: November 21, 2014, 07:15:47 am »
NV 3500 5 speed from
A 97-07 pickup
The full size had a 4.0 first gear and the S-10 had a 3.50 first gear ratio
Depending on your Tires and axle gear one may work better
If your truck is 2WD. The swap is way easier
« Reply #3 on: November 23, 2014, 06:55:46 pm »
My main concern is can I do a swap with out having to lengthen my drive shaft?
My truck is 2wd with the 131.5? Wb and one piece drive shaft.
« Reply #4 on: November 23, 2014, 08:27:24 pm »
I am not familiar with the NV3500 overall length but there is no drop in standard transmission that I know of that will not require some drive shaft length modification.
« Reply #5 on: November 24, 2014, 11:18:42 am »
Is the TH350 a long tail or short tail.  A ST-10 trans is very short.  Potentially meaning you will need to lengthen the driveshaft.
« Reply #6 on: November 24, 2014, 10:11:46 pm »
It's the long tail 9" I'm not to concerned with what type manual trans to put in either a 4 or 5 speed would be fine. Just the driveshaft issue sucks
Offline roundhouse
« Reply #7 on: November 24, 2014, 11:13:24 pm »
New d shaft is about $200
That's a deal killer?
« Reply #8 on: November 25, 2014, 09:42:57 am »
Definitely will need a longer driveshaft.
« Reply #9 on: November 25, 2014, 11:02:50 pm »
Where would I get/ buy the right size drive shaft?
« Reply #10 on: November 25, 2014, 11:22:41 pm »
your th350 with 9" tail should be 30 11/16". you have to find a drive shaft shop near by. might luck out and be able to find one at a junkyard or off the truck where you get the trans from.
dont know if this will help but its a guy who went from a th350 to sm465
http://coloradok5.com/auto2manual.shtml
Offline roundhouse
« Reply #11 on: November 26, 2014, 08:44:40 am »
when did they put 4 speeds in Impalas?
1969?
Should be a shop within a few miles that makes shafts
Unless you live in the boonies
There are also several mail order companies
Six states
And
Tom woods
Are the largest
Id get a 5 speed from either 97-07 silverado Or 97-whenever they stopped making the S-10
Depending on your tire size and axle gearing
One may work better than the other based on the ratio of first gear
Find a donor vehicle and get as much as you can
Clutch master cylinder , slave cylinder
Resivior
Line from MC to slave cyl
Driveshaft
Shifter and boot and anything else you think you might need
Easiest way is to find a set of hydraulic pedals from a 85-87 square body and swap em in
You can make a mechanical pedal set work but it's time consuming
« Reply #12 on: November 26, 2014, 09:19:04 pm »
That's the problem I do live out in the boonies (west chazy ny 12992)
So there's nothing around here far as good junk yards or really anytype of shops.ugh
