Author Topic: Dual fuel tank switch ultimate fix....  (Read 8551 times)
Offline bigkahuna4444
« on: November 22, 2014, 06:51:23 pm »
I have been fighting with the electric switch valve and fuel gauge switch since I have bought my truck 2 years ago. The switch would always work fine until i was in the woods or on some desolated back road and it would stop functioning. The gauge never switched tanks properly, but i just got used to watching the miles run on each tank.  I have replaced the valve multiple times and the sending units multiple times. Ive read and reread every post on this forum countless times (thank all of you for all your help)   I finally came to the conclusion that the system is just unreliable and prone to breaking. I found a boat fuel valve that has both a supply and return port. I welded a bracket under the cab and ran the valve handle into the cab just under the seat where you can reach it when driving. I wired up two separate gas gages, one dedicated to each tank.....no more issues and a fuel system that is fool proof (knock on wood).  Hoping this idea may end someone elses frustration.
Re: Dual fuel tank switch ultimate fix....
« Reply #1 on: November 22, 2014, 10:37:05 pm »
part numbers?
Offline flips87c30
« Reply #2 on: November 22, 2014, 10:50:29 pm »
Yes part numbers please. I like the simplicity.
87 v30 duelly dump truck 454, th400, np205, dana 60/14 bolt, warn hubs, gmt800 mirrors and LEDs all around the bed.
Offline roundhouse
« Reply #3 on: November 22, 2014, 11:08:15 pm »
Nice
Offline duallydmax06
« Reply #4 on: November 24, 2014, 05:42:33 pm »
This is a great idea....maybe a diy write up and yes part numbers would be cool
2010 ccsb 4×4 duramax
1985 sclb k20
1979 sclb k20
1971 sclb c20
1928 model a coupe hot rod
Offline DuckAholic1
« Reply #5 on: November 24, 2014, 05:45:48 pm »
awsome & ditto!!!
« Reply #6 on: November 26, 2014, 08:37:47 pm »
Groco FV65038 6 Port Fuel Valve....about 170 bucks online....the fuel gauges are simple napa generic gauges.    nothing fancy and thats makes me feel good in the back woods.
« Reply #7 on: November 26, 2014, 08:43:33 pm »
very simple bullet proof part with a theft proof setting to off (doubt they ever look under the seat for a valve handle)
Offline DuckAholic1
« Reply #8 on: November 27, 2014, 10:23:15 pm »
Thanks for sharing the info!
