spool?
Topic: spool? (Read 4995 times)
newmans75-k20
spool?
December 09, 2014, 10:05:16 pm »
I blew up my carrier a few weeks ago and thinking about putting a spool in does anyone have a opinion on these ive got a dana 44 and 4.10s I can get the spool for 100 and a rebuilt posi for 150
FlatBlack77
Cheap Fast Reliable - Pick 2
Re: spool?
December 09, 2014, 10:13:44 pm »
is it a street driven truck?
newmans75-k20
Re: spool?
December 09, 2014, 10:18:11 pm »
some times mostly just to the trails ive got the lockout hubs to disengage so
Re: spool?
December 10, 2014, 07:41:36 am »
I personally wouldn't run a spool on the front.
newmans75-k20
Re: spool?
December 10, 2014, 10:56:14 pm »
if ya don't mind me askin why wouldn't you run the spool?
Re: spool?
December 10, 2014, 11:41:11 pm »
a spool up front is just like welding the gears. you have no slippage and when you try and turn right the right tire wants to roll back and the left wants to roll forward but with a spool locking the two it makes it almost impossible with out the engine running and then it puts a lot of stress on other parts including the frame.
if you have lock outs you can keep one unlocked and this will give that side all the power and makes it street able but again that wheel will be turning no matter what your doing and could cause you to lose control
Re: spool?
December 10, 2014, 11:50:51 pm »
If you do, have spare u-joints and axles. Spools never differentiate, so if you are on something other than loose ground it will put some stress on the steering. So make sure you reinforce/support the frame prior.
fitz
Re: spool?
December 10, 2014, 11:53:12 pm »
There must be some reason that on the M1028 the Military went with a Detroit locker in the rear and a limited slip (not a locker):in the front.
Engineer
Re: spool?
December 11, 2014, 07:28:07 am »
After installing a spool/welded front diff most guys start breaking the short axle shaft.
I recommend a clutch type or Torsen type positraction differential for the front. I'm not a fan of lockers or a locked differential in the front unless it is strictly a mud only application.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Fodder4U
Goob
Re: spool?
December 20, 2014, 08:30:51 pm »
Or you can get a lunchbox locker like an Aussie and get away with it.
1979 C10 SWB 4.1L Auto
spool?
