Author Topic: whats the ultimate 350 tbi  (Read 8549 times)
Offline gmcdwight
« on: September 15, 2006, 07:11:00 pm »
I have a 87 350 tbi that i won't to build up.I want lots of low end torque and good horsepower numbers.I also would like a choppy camshaft.Everyone let me know what the ultimate 350 tbi build up would consist of .
Offline lotopp79
Re: whats the ultimate 350 tbi
« Reply #1 on: September 15, 2006, 07:58:00 pm »
go to tbi chips you can find him on ebay hes into making perfomance ships and can give you an idea of what you can do with you tbi but its not like building a plain old carbed engine it take a little fines to make the comp happy
Offline RSBAD454
« Reply #2 on: September 16, 2006, 10:52:00 am »
I doubt an EFI engine will like a lumpy camshaft.....you will need a cam that will work with the ECU to make it Happy. Typically, lumpy cams produce lower engine vacuum and more cam overlap which means a bad A/F ratio for O2 sensor. I would build a 383 and keep motor basically stock with bolt ons. You want torque for pulling or for drag racing?
Toys are my game
http://
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #3 on: September 16, 2006, 08:33:00 pm »
I concur. A 383 Stroker will give you more bang for the buck.  Stroke that 350 out with a 400 crank shaft, balancer and flywheel.
here's a gm crate 383 ho
SgtDel
aka "Andy"
www.delbridge.net
1979 Big 10 383 stroker
1991 Blu 'Burb 3/4 ton 4x4
Edited by: SgtDel  at: 9/17/06 10:08 am
Offline RSBAD454
« Reply #4 on: September 18, 2006, 08:03:00 am »
You can pickup rotating assemblies pretty cheap anymore to build a 383 out of a 350. That is what I plan on doing for my 91 down the road here.
Toys are my game
http://
Offline Qship406
« Reply #5 on: April 02, 2007, 12:06:00 am »
Choppy camshaft and EFI is a bad combination......EFI can not handle low vacuum cams at all, even with a chip.
« Reply #6 on: April 02, 2007, 09:42:00 pm »
Not true and are you FAST68? :lol
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
« Reply #7 on: April 03, 2007, 11:05:00 am »
I think so---a September thread:rollin
SgtDel
aka "Andy"
www.delbridge.net
