Members Rides
My build
4
5
Topic: My build (Read 39113 times)
JoshsC10
Re: My build
Reply #45 on:
January 04, 2015, 04:22:32 pm »
Got the rear finished, still waiting on jegs to send front lowering springs. I think it's going to look good.
JoshsC10
Re: My build
Reply #46 on:
January 07, 2015, 06:24:20 pm »
Hey another quick question, I'm replacing upper ball joints and got the old one removed but the new one acts like it doesn't want to go in?? I'll try searching on the forum also thanks
JoshsC10
Re: My build
Reply #47 on:
January 07, 2015, 06:33:05 pm »
Figured it out! Here's my sign
JoshsC10
Re: My build
Reply #48 on:
January 10, 2015, 05:49:32 pm »
Installed new ball joints last night and now finally got springs will post pics once I get it on the ground. Anybody have any rubbing issues with the 4/6 kit? Thanks
JoshsC10
Re: My build
Reply #49 on:
January 10, 2015, 07:17:55 pm »
Before and after: seems like the front needs to come down just a little more?
Re: My build
Reply #50 on:
January 10, 2015, 10:09:41 pm »
Have you driven it yet? If not drive it first it will settle.
squarebody.biz
JoshsC10
Re: My build
Reply #51 on:
January 12, 2015, 08:57:46 am »
Ok thanks, I've drove it once I'll give it a few days
Re: My build
Reply #52 on:
January 13, 2015, 10:01:22 pm »
You need to drive it around and let it settle some before you start changing things. 4/6 should put the truck about level
JoshsC10
Re: My build
Reply #53 on:
January 14, 2015, 04:23:01 pm »
Thanks, I've drove it about 50miles since I've lowered it just thought they would of settled by now?
I have a vibration problem I've been trying to fix now.
JoshsC10
Re: My build
Reply #54 on:
January 14, 2015, 09:19:49 pm »
Well new problems now, I've taken the bed off again to fix my rear end (bad vibration) and the frame is getting into the shocks real bad , dented them in a tiny bit. Should I get a shock relocation kit?? Anyone else have one of these belltech kits that may have had similar problems. Thanks
JoshsC10
Re: My build
Reply #55 on:
January 14, 2015, 09:29:20 pm »
There called rear shock extenders not relocators
Re: My build
Reply #56 on:
January 15, 2015, 10:09:41 pm »
If you got a flip kit you need shock extenders so the shocks won't bottom out. They should work without them though. How long is your shock bracket?
JoshsC10
Re: My build
Reply #57 on:
January 16, 2015, 08:15:24 am »
Im not sure its just the stock one, I talked to belltech and they said its because I removed the overload spring? Do u think that would make it that much lower without that leaf, to cause it to hit?? Thanks really appreciate all the help.
JoshsC10
Re: My build
Reply #58 on:
January 16, 2015, 08:20:52 am »
Pointing where it's hitting
JoshsC10
Re: My build
Reply #59 on:
January 16, 2015, 08:24:02 am »
4
5
Members Rides
My build
