Author Topic: Paint/dye help  (Read 5389 times)
Offline cyclops1032
Paint/dye help
« on: December 17, 2014, 06:08:18 pm »
I have a set of charcoal door panels for my 1981 Scottsdale that I need to change to a light beige. I have read many ways to do this but which way is the best? Also how many cans of color will it take for 2 door panels and 2 armrest pads?
Re: Paint/dye help
« Reply #1 on: December 17, 2014, 07:35:13 pm »
SEM is your best option in my opinion if you want to use a spray can.  Duplicolor works also.
If you want to use a spray gun, go to your local Automotive paint supply store (that the dealership uses) and get some from them.
Offline 78BIG-TEN
Re: Paint/dye help
« Reply #2 on: December 18, 2014, 02:09:32 pm »
If your not picky on the shade then SEM works well.If you are,then go to your local paint store and they can mix any shade you like.If you don't have a spray gun,most auto parts or paint stores have an aerosol spray canister with a jar on the bottom that works pretty good.But beware the dye at the paint store may run 150 bucks a quart or more
Offline cyclops1032
Re: Paint/dye help
« Reply #3 on: December 21, 2014, 11:53:37 am »
So I need to clean, apply adhesion promoter, primer and then the color?
Offline 78BIG-TEN
Re: Paint/dye help
« Reply #4 on: December 21, 2014, 04:56:57 pm »
I asked the guys at the paint store about prep for the dye,specifically promoter.
They told me to just clean really well with soap and water and then wipe down
with a grease remover or alcohol and then tack it off.I used alcohol and all
went pretty well.Laid down 3 coats with the first one just a mist coat.
Offline LTZ C20
Re: Paint/dye help
« Reply #5 on: December 21, 2014, 06:48:08 pm »
You don't have to use the adhesion promoter, I have used SEM both with and without promoter,  got about the same result. I like it without because it let's the dye get directly onto the material and stick better.
LTZ Cheyenne C20
Offline cyclops1032
Re: Paint/dye help
« Reply #6 on: December 22, 2014, 05:08:23 pm »
Thanks
