Author Topic: Engine swap diary  (Read 118912 times)
Offline Stewart G Griffin
Re: Engine swap diary
« Reply #45 on: April 12, 2015, 07:16:38 am »
Thanks.  i can't do any drilling until the Trans mount arrives.  This should hopefully get the engine and trans centered properly.
Offline gutts
« Reply #46 on: April 12, 2015, 08:24:39 pm »
i'm thinking i might just go with a new crate 350 and be done with it.   :(
Rice burner ?
« Reply #47 on: April 13, 2015, 08:11:58 pm »
Rice burner ?
i decided to bite the bullet and go ahead with the v-6.  i figure i'd be happier that way in the long run as i rarely tow or haul heavy and basically use the truck for transportation---with the occasional ability to pickup bulky items for weekend projects.   If i had gone with the crate 350, the truck would most likely be running by now.   But i don't think i'd be as happy in the long run.
« Last Edit: April 19, 2015, 05:06:29 pm by Stewart G Griffin »
« Reply #48 on: April 19, 2015, 04:37:03 pm »
Ok, i got the new trans mount installed and the trans crossmember put back in place.  It did seem to help get everything centered up.  i went with Energy Suspension pt.# 3-1108.  It's polyurethane which i think is more durable than the stock rubber mount.  It was $25 or so at Jeg's.
Next, it's on to drilling which i may not be able to get to until next weekend, but hopefully sooner.
i know Greybeard mentioned using a split-point bit which i will look into.
Any other tips for drilling?
« Reply #49 on: April 19, 2015, 05:14:50 pm »
slow and steady, use cutting oil (regular motor oil works) and let the bit to the work.
Offline Greybeard
« Reply #50 on: May 12, 2015, 09:39:39 pm »
Hey,
   Google split point or pilot point drill bits. They cut faster and much easier than a regular bit. The trick is to get the drill speed at the speed the bit wants. A variable speed drill is best obviously, A cobalt bit drills better and faster than a HSS bit (by hand) but cost considerably more. Drilling is as much art as science. Perfect pressure and bit speed with a steady drill motor (no rocking) and it amazing how easy hand drilling can be, get any of those things seriously wrong and it can become the greatest frustration known to man. A high quality cutting oil is best, and they usually evaporate with little or no trace. I haven't used regular motor oil for drilling in a couple of decades but IIRC it smokes a lot and carbonizes more.
« Reply #51 on: May 13, 2015, 08:52:22 pm »
Thanks for the drilling tips.  i will not be able to get to this for a while because something came up.
The only things left are:
Drill holes in frame for the new mounts
Exhaust re-work  (small block is slightly different from v-6.  Different enough to where it's not a bolt in)
New/different radiator hoses/trim heater hoses to fit.
Figure out throttle cable /kickdown cable mounting. May be able to use v-8's
Reprogram tach to run on 6 cylinders instead of eight.
Reconnect temp gauge
May have to lenghthen power steering hoses
May have to lenghthen fuel lines to fuel pump.
Reconnect alternator and starter wiring.
Install electric fan properly
« Reply #52 on: May 31, 2015, 03:25:11 pm »
What size should the hole be drilled at?     i'm thinking 3/8"?
« Reply #53 on: May 31, 2015, 03:41:19 pm »
Same as what the V-8 perches used.  Pretty sure they are bigger than 3/8"
« Reply #54 on: May 31, 2015, 06:12:06 pm »
Believe it or not, i think they really are 3/8."   Drilling went ok.   i used a transfer punch because i already had the engine in and did not want to go thru the hassle of disconnecting the trans and taking the engine out etc.  So i actually drilled thru the holes of the mounts.
i used a drop of regular oil every 20 seconds or so.
And got all the perch bolts in.
« Last Edit: May 31, 2015, 09:26:24 pm by Stewart G Griffin »
Offline Greybeard
« Reply #55 on: June 12, 2015, 02:15:14 am »
Good deal! This my regular bimonthly rollaround through here. If regular oil works use what ya have. I remember we had some of the foulest looking thick black cutting oil I've ever seen at work, and it stank to high heaven, but it worked. All it's for is to cool the cutting edge by/and providing lubrication. It stands to reason that whichever side is hotter is also softer. The kicker here is that the cutting edge of a drill bit is very thin, therefore easier to heat up.
I have always preferred cutting holes through a preexisting hole. Cit the first hole insert bolt and tighten, rinse and repeat.
« Reply #56 on: June 14, 2015, 07:09:47 pm »
Ok, engine is officially in truck----all perches/mounts are bolted in and tightened.  The perch bolts are 9/16" socket and the nuts seemed to work best with a 15mm boxwrench.
Next, both fuel lines(the rubber part) will have to be lengthened to reach the fuel pump.   Would anyone happen to know the sizes of the rubber hoses, both supply and return, going to the fuel pump?
« Last Edit: June 14, 2015, 07:20:46 pm by Stewart G Griffin »
« Reply #57 on: June 20, 2015, 05:19:59 pm »
Fuel hoses installed.  i went with Thermoid brand fuel injection hoses.  5/16" for supply, 1/4" for return.
Exhaust
Radiator hoses
Throttle/trans kickdown
Vacuum booster brake line
Tighten converter/bellhousing and transmount bolts to correct specs
Reprogram to tach for 6 cyls
reconnect temp gauge
Install starter
Install alternator
Install P/S mounts and extent P/S lines
Intall electric fan properly
« Last Edit: June 20, 2015, 05:22:11 pm by Stewart G Griffin »
« Reply #58 on: June 20, 2015, 06:50:53 pm »
Radiator hoses from the 4.3, surprisingly, bolted right up to the v-8's radiator.  May provide pics tomorrow if there is time.
NEXT CRISIS:
Throttle bracket and cable are too far back to work  (cable has bottomed out in this position)   The kickdown cable, i think, can be adjusted but i'm not sure.   Any suggestions?
« Reply #59 on: June 21, 2015, 10:15:28 pm »
Ordered new, shorter, correct throttle cable "Pioneer Automotive" brand from summitt.  Apparently on the 4.3 the carb sits a few inches further back compared to the v-8. Probably about 4.5" further back----the v-8 cable is like 24"and some change and the v-6 cable is 20.75"
Working on installing brake booster line to back of carb, intall throttle bracket and adjust kickdown cable if it can be adjusted?
Will provide pics asap.
