Author Topic: is my cam to big for stock springs  (Read 8034 times)
Offline jnmac
« on: April 07, 2007, 07:58:00 pm »
im looking at getting a Melling #MTC1 Torque cam 204/214 dur @ 50 .420 .443 lift. the guy that helps me get the right parts is out of town . so i come to ask u guys thanks
Offline jnmac
Re: is my cam to big for stock springs
« Reply #1 on: April 07, 2007, 09:40:00 pm »
o by the way its a 79 350 bone stockin a 3/4ton scottsdale4x4
Offline 79SHORTWIDE
    • 79 SHORTWIDE
« Reply #2 on: April 08, 2007, 10:01:00 am »
It sounds like the same as an Edelbrock Performer cam. It is ALWAYS a good idea to change the springs out to match the cam. They're usually less than $100.00. Worth the money to be on the safe side. Plus, your o.e. springs have probably weakend over time. How is the bottem end of the engine? An Edelbrock Performer or equivalent intake with about a 600 cfm carb (vacuum secondary design) willl work very well with that cam. A decent dual exhaust system with 2 1/4 pipes as well.
« Reply #3 on: April 08, 2007, 10:15:00 am »
That cam is nearly the same as your stock cam. Your OE springs will work fine with it.
Offline jnmac
« Reply #4 on: April 08, 2007, 10:50:00 am »
the bottom end is great on this motor really the hole motor is good but its starting to smoke when u lug on it so im pulling in and rebuilding it. and i thought i would put a little bigger cam in it
Offline 82stepside
« Reply #5 on: April 11, 2007, 07:01:22 pm »
Cam tech has come a long way since that grind was produced.
That grind is like 30 years old.
Spending a few more $$$ for a grind like the Comp XE252 will be worth it.
Just my $.02
1982 stepside
355
world torquers
Comp XE256
Th350/3.08 posi
1982 Stepside
355 4 bolt
World Torquers
Th 350/3.08 posi
Offline SUX2BU99
« Reply #6 on: May 03, 2007, 12:23:40 pm »
82stepside, how does that powertrain combo work for you? I'm thinking something similar with some 1.94 or 2.02 heads ($4-500 rebuilt from a motor shop on Ebay) and either a Comp 262 or 268 Xtreme cam. Rest of my motor is pretty much stock (see the other thread in this forum called "Tell me what you think of this motor" for a description of my current setup).  You have lots of power with that?
