Author Topic: Problem with 83 Chevy C10 Brake Power Booster/Mastercylinder  (Read 5122 times)
Offline larry h
« on: December 23, 2014, 09:03:57 pm »
 hello have a 83 c10 custom delux 1/2 ton changed my booster and master to a 4x4 booster with the dual diaphram  the  question is are the  brake pedal rods the same length  when i push the brake pedal the rear of the master cyl raises up like it is going to pop off in the back
Offline larry h
« Reply #1 on: December 27, 2014, 06:51:20 pm »
Installed new brake booster and master cylinder from Advance (total kit) and the reservoir raises up like it is trying to pop off the master cylinder when you push in the brake. ???  :o ??? Have bled brakes, new shoes, rotors, wheel cylinders and have replaced the booster/master cylinder kit twice thinking it was a defect but same issue. When I take the cap off the reservoir air does push out. ??? What could be the issue? Has anyone had this issue before? Solutions?
Re: Problem with 83 Chevy C10 Brake Power Booster/Mastercylinder
« Reply #2 on: December 27, 2014, 06:59:24 pm »
What do you mean it raises up? Is your firewall rotted or something? Post pics or a vid or explain better.
