Author Topic: 350 torque converter lockup  (Read 4132 times)
Offline jay_c
« on: December 24, 2014, 01:49:04 am »
Sirs/ma'ams,
 I have a 81 c10 with a 350/350. The previous owner hacked up the wiring pretty bad and I now have a truck with the tq converter lockup wires and vacuum line that are not connected and cut. My question is do I NEED to have a converter lockup mechanism? Since they are not even connected I'm thinking of removing it unless I need it. Thanks in advance.
Offline 78BIG-TEN
Re: 350 torque converter lockup
« Reply #1 on: December 24, 2014, 09:29:03 am »
vacumn line should be hooked to manifold vacumn.You don't have to do the lockup,when working they can give 2-3 mpg on the highway
Offline LTZ C20
« Reply #2 on: December 24, 2014, 09:53:51 am »
Going from not having a lock up converter to having one, I highly suggest fixing it. You will be very pleased.
LTZ Cheyenne C20
« Reply #3 on: December 24, 2014, 11:26:39 am »
It will help with mileage hooked up.
squarebody.biz
Offline jay_c
« Reply #4 on: December 24, 2014, 04:11:27 pm »
Thank you for the replies. I don't drive the truck enough to need to worry about mpg. I will remove the wiring after x-mas and post some pics since it should clean up the engine bay a little. I even bought a new brake light switch with only two prongs. This way it will look as if the TC wire was never there. Thanks again guys, Merry Christmas.
Offline Stewart G Griffin
« Reply #5 on: January 04, 2015, 02:13:26 pm »
Isn't the 350C's lockup controlled by computer?   i noticed that i have 2 wires running from the vacuum switch on the firewall going to the esc computer area?
Offline 78BIG-TEN
« Reply #6 on: January 04, 2015, 03:03:29 pm »
I was thinking from a pressure switch on right side of trans,not sure ,been a long time since I messed with one
