Author Topic: 1985 C30 SM465 to TH700R4 conversion  (Read 4261 times)
Offline Fatmanz85
  • Old but Newbie
« on: December 24, 2014, 07:27:32 am »
Hate to give up the stick shift, good power, but the clutch is no longer my friend...... bad knees and getting older, I find I need a automatic. I have a 1988 C2500 with a good TH700R4 in it,( good low mileage running gear just bad body). Has anyone done this swap before?
« Last Edit: December 24, 2014, 07:48:39 am by Fatmanz85 »
1985 C30 Crew Cab Silverado, 6.2L 3 speed granny
Re: 1985 C30 SM465 to TH700R4 conversion
« Reply #1 on: December 24, 2014, 08:48:30 am »
i blew out my knee when i was 17 or so, when i drive my 79 (sm465) it bothers me and my knee starts shaking if i have to hold the clutch in long. so i feel your pain, im looking for the swap if i can find one ill post it
« Reply #2 on: December 24, 2014, 09:22:53 am »
Pretty straight forward swap. See if your radiator is already setup for a transmission cooler. If you are making it column shift you'll need the linkage, column etc. Driveshaft length will be different.
Offline roundhouse
« Reply #3 on: December 24, 2014, 10:58:37 am »
A hydraulic clutch would be a lot less leg effort
« Reply #4 on: December 24, 2014, 11:21:11 am »
1985's are juice clutches
Offline roundhouse
« Reply #5 on: December 24, 2014, 10:38:20 pm »
wonder if you could use a brake MC and a hydroboost or a vacuum booster
To reduce the pedal effort to almost zero ??
Alot of big trucks have a air assist on the clutch
« Last Edit: December 27, 2014, 10:38:02 am by roundhouse »
