Engine/Drivetrain
Transmission/clutch problems?
Topic: Transmission/clutch problems? (Read 22318 times)
moneyg77
January 04, 2015, 06:38:51 pm »
I hearing/feeling something bad coming from the tranny when i come to a stop and its gradually getting worse. It feels like my clutch is about to fall out!! I dont know much at all about tranny's so any help would be greatly appreciated.
I have an 81 k10 with 350/muncie 4 spd.
Thanks in advance
1981 K-10 longbed stepside 350/465/208/quadrajet. 6"lift, 35" BFG, custom exhaust
1983 K-10 swb 4"lift
1986 lwb fleetside
Jason S
Re: Transmission/clutch problems?
January 04, 2015, 07:02:38 pm »
If it's noise when you push in the clutch, it could be a bad throwout bearing.
moneyg77
January 04, 2015, 07:25:09 pm »
There aren't any noises when the clutch is pushed in, only when coming to a stop..
1986 lwb fleetside
January 05, 2015, 09:32:52 pm »
Coming to a stop with your foot on the clutch or off? Can you get a video of it?
moneyg77
January 06, 2015, 05:03:20 pm »
Its while coming to a stop with my foot on the clutch. I'll see if i can get a video and load it as soon as possible.
1986 lwb fleetside
moneyg77
January 07, 2015, 05:47:23 pm »
Okay, so i was finally able to add a short 10 second video on youtube so that you guys can kind of hear whats going on. I hope its enough, If not then ill add another. Disregard the squeaking brakes and bad interior lol my focus is on the mechanics for now.
I tried stopping with it in gear and not in gear. It feels like once i get slow enough something locks into place, causing the abrupt stop. It alsosometimes pops into gear when i come off the clutch and push on the gas.
This is the link
https://www.youtube.com/watch?v=UH0pEq4PPyU&feature=youtu.be
Thanks
1986 lwb fleetside
Engineer
January 07, 2015, 08:25:21 pm »
Check your u-joints first, and foremost.
Eliminate those before suspecting the clutch.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
moneyg77
January 07, 2015, 08:31:49 pm »
I know for sure the front u joint is fine, it was just recently changed out. I even disconnected the front driveshaft to be sure. Any other suggestions?
1986 lwb fleetside
moneyg77
January 07, 2015, 10:23:13 pm »
I guess i have a real stomper huh?
1986 lwb fleetside
January 07, 2015, 11:01:44 pm »
sometimes you have to give us a day or two to get back on. but i cant watch the video for now(firewall), but does it do it when you coming to a stop and take the trans out of gear?
moneyg77
January 08, 2015, 12:25:16 am »
Copy that.
It does it with the transmission in gear and out, but not as I take it out of gear if that makes sense.
1986 lwb fleetside
January 08, 2015, 12:46:03 am »
try to take it out of gear by the t case when your stopping. then see if it make the noise anyway you can with the t case in neutral
moneyg77
Reply #12 on:
January 08, 2015, 05:15:44 pm »
I took it out for another drive and noticed that every time I let of the gas I hear a grinding noise, hope that helps.
1986 lwb fleetside
Reply #13 on:
January 09, 2015, 06:28:09 pm »
I really couldn't tell what noise to listen to in the video. Are the axles ok? Pinion nuts?
Engineer
Reply #14 on:
January 09, 2015, 06:47:40 pm »
It is starting to sound more like a countershaft bearing in your transmission. Or as Capt said a bad pinion bearing.
Engine/Drivetrain
