What is this fluid?
Topic: What is this fluid? (Read 15844 times)
Chisholmcody
What is this fluid?
January 06, 2015, 01:13:22 pm »
So the truck has sat for about 2 weeks due to the snow in Colorado. Today I was getting ready to go but then I got the idea to check all my fluids. They all checked out well.
So then I peak under the truck due to the fact that there's always been a "small" leak from some place. And this is what I see
Then I smelt it to try and see what it was but the scent isn't strong enough to tell. So I was wondering if someone on the forum could tell what it is by the picture.
Thanks in advanced!
LTZ C20
Re: What is this fluid?
January 06, 2015, 01:46:02 pm »
Where was the pan located under the truck? My first thought is oil.
LTZ Cheyenne C20
Chisholmcody
January 06, 2015, 02:19:20 pm »
It was located directly under the motor...I checked the oil and it still reads full though.
LSXCHEVY
January 06, 2015, 02:46:20 pm »
looks like oil to me....maybe not enough leaked out to show low level?? what is the viscosity of the fluid...watery or thick ?
ehjorten
January 06, 2015, 03:58:09 pm »
That little bitty-bit of oil will not show on the dipstick.
-Erik-
roger97338
January 06, 2015, 08:49:53 pm »
If it feels like oil, I'd guess oil. If it feels watery, I'd guess cat urine. Mine will relieve themselves in anything that looks vaguely like a litter box, if it's on the ground.
LTZ C20
January 06, 2015, 09:11:15 pm »
Haha roger. That made me lol. That small amount of oil will not drop the level of the dipstick. Lay under the truck and look around till you find something that looks like it was leaking. Mostly likely around anywhere oil gets to, oil pan, valve cover sides nearest the exhuast manifolds, oil pressure sensor, rear main seal, timing cover crank seal.
LTZ Cheyenne C20
Chisholmcody
January 06, 2015, 09:20:44 pm »
So it does look like the oil pan is leaking a little bit. How hard is it to do the pan gasket on a 1978 chevy cheyenne with a l6 250
Sent from my iPad using Tapatalk
LTZ C20
January 06, 2015, 09:25:06 pm »
I don't know how hard it is for a I6, my Cheyenne with a 350 was pretty easy.
LTZ Cheyenne C20
roger97338
January 06, 2015, 11:02:28 pm »
I think 'easy' is a relative term here. If I had a nice, warm, dry shop which had a vehicle lift, and all the tools were clean and easy to find, I'd likely be so happy that I'd install it, remove it, then install it again! However, if I had to lay on an icy or snowy gravel driveway, with melt water trickling down my neck, it's very likely that I'd consider it so difficult I'd either pay someone to do it, or wait until spring to do it myself.
LTZ C20
January 07, 2015, 01:47:18 am »
Haha yea. I did mine once on a lift in our shop and the second time upside down, well, the engine was upside down...and on an engine stand....cuz I was building it. Haha.
LTZ Cheyenne C20
frotosride
January 07, 2015, 04:17:39 pm »
Taste it... It's a fool proof way to figure out leaks. Growing up poor has lead me to a keen sense of taste when it comes to leaking vehicles! If the taste is bitter it is certainly brake fluid or power steering fluid. If it has a little gas taste to it, likely engine oil. If it taste like the smell of old bearing grease then its heavy weight gear lube. And if it is sweet it is certainly antifreeze. With one exception to that, if you have a/c and its r134a the the mineral oil used as the lube in the compressor has a slight sweet taste but easily distinguishable from antifreeze.
Last Edit: January 07, 2015, 04:20:36 pm by frotosride
Chisholmcody
January 07, 2015, 05:25:35 pm »
Lol maybe I'll have to give it a taste before I dig into the oil Pan project
January 07, 2015, 06:11:51 pm »
Dude, don't eat, lick or taste it.
If it's brake fluid it will rinse off clean with warm water. If it is oil it will not.
⌠ŻŻŻŻŻ' [☼===☼]
LTZ C20
January 07, 2015, 08:18:01 pm »
Froto you got problems haha. As vile said, you only have to touch it to know what it is. Please don't put any of the fluids into your mouth......or lick the windows.
LTZ Cheyenne C20
What is this fluid?
