Electrical
Headlight troubles
Topic: Headlight troubles (Read 15641 times)
Ds2014
Headlight troubles
January 16, 2015, 06:20:07 pm »
Hi guys don here 81 c10 short stepside. I just installed jegs 16 circut harness and can't get the turn signals on the drivers side to work on their own. And the top light comes on even in low beam.
dvdswan
Re: Headlight troubles
January 17, 2015, 02:24:16 pm »
so do the l/s turn signals come on when the hazards are on? Is the top light a hi/low beam light? do both sides come on?
Dave
78 K10 Stepside
http://s36.photobucket.com/user/dvdswan/story/10553#
Ds2014
January 17, 2015, 03:28:03 pm »
The left side does work with hazards on the top light is the one with two prongs and yes both sides come on
dvdswan
January 17, 2015, 09:53:22 pm »
how are the grounds? you didn't put them on a painted surface did you?
Dave
78 K10 Stepside
Ds2014
January 18, 2015, 01:57:51 pm »
I just redid all the grounds
Ds2014
January 18, 2015, 02:04:53 pm »
The hi beams are very very dim when it's on low beam setting. Hi beams work great when in hi beam setting. T/s don't work when headlights are on
Ds2014
January 18, 2015, 05:53:30 pm »
Here's a picture
dvdswan
January 18, 2015, 11:43:17 pm »
is your left side bulb burnt out? its not lit up in the pic.
Dave
78 K10 Stepside
January 19, 2015, 12:16:09 am »
i would think its a bad connection
January 19, 2015, 10:08:34 am »
Are you saying your headlights come on without the switch and the left turn stays on or?
I sounds like you have something wired wrong.
Ds2014
January 19, 2015, 10:50:22 am »
No I cut them loose to see if it had an effect and no it didn't. I'm about to loose my mind all grounds good I jumped the switch. And dimmer switch still same thing
Ds2014
January 19, 2015, 10:52:11 am »
No the switch works fine when I turn the lights on the low beam setting the pic is what it does you can see the top lights very dim. When I turn hi beams on they work the way they are supposed to
January 19, 2015, 10:55:02 am »
In the pic the lows look pretty bright to me. Don't compare them to new cars if you are using stock lamps. Cars behind me flood out my factory type bulbs on low...
Ds2014
January 19, 2015, 11:06:40 am »
I have them in the wron spot the bottom supposed to be high right?
January 19, 2015, 11:54:08 am »
tops low, all 4 are high or the bottom
Electrical
Headlight troubles
