Author Topic: intermittent wipers to a truck without them  (Read 5105 times)
Offline hotterodder
« on: January 16, 2015, 11:54:37 am »
I know this an old thread...but...I have a'78 gmc Sierra, I have replaced the wiper motor, then put in a new delay switch and module. It had a two speed wipers before, but now the wiper delay feature only works once then they stays on continuously. Switch, module and motor are new...any ideas?
1979 K30 Chevy 1 ton 4X4 PU
1978 K35 GMC 1 ton 4X4 PU
Re: intermittent wipers to a truck without them
« Reply #1 on: January 16, 2015, 11:21:47 pm »
Not enough info. You need to give details, what year components did you use, is this a factory setup? Check your connections and circuit grounds. Where did you get your parts from?
Offline roundhouse
« Reply #2 on: January 18, 2015, 06:13:39 am »
I think the motor has to be an intermittent motor
Not the regular motor?
Also gotta have the intermittent wiring harness from the switch to the motor
Offline LTZ C20
« Reply #3 on: January 18, 2015, 07:29:40 am »
Roundhouse, the regular motor is fine. My buddy just did this to his truck last week. Switch and module are all you need. His work like brand new.
LTZ Cheyenne C20
Offline roundhouse
« Reply #4 on: January 18, 2015, 09:37:57 am »
Nice to know
I thought I had read somewhere that you had to have compatable motor
Or maybe some of the early ones 73-75 maybe ? Didn't work with the intermittent  because they didn't have enough wires or something
Offline LTZ C20
« Reply #5 on: January 18, 2015, 06:36:47 pm »
Roundhouse,  not sure bout that. But I know it's a to-do item for my truck.
LTZ Cheyenne C20
Offline 78BIG-TEN
« Reply #6 on: January 19, 2015, 09:24:24 am »
I did my 78 back in the early 80's.simple pnp.Didn't need the motor
Offline hotterodder
« Reply #7 on: January 19, 2015, 12:26:54 pm »
Everything is new, motor from local auto parts store, switch and module from online vendors, ordered stuff for a '78 GMC. Wiring looks good, no frankenstien, bought the truck last year from the original owner, 98,000 original miles.
