Author Topic: Lets play the guessing game  (Read 5940 times)
Offline traumajunkie
« on: January 27, 2015, 11:50:56 am »
Ok I just recently bought a 1984 c10 with a straight 6, I went to do the nc safety inspection and failed because of some missing hoses, i cant tell by looking at the emissions paper where they go...
911 Please State Your Emergency
Re: Lets play the guessing game
« Reply #1 on: January 27, 2015, 01:14:24 pm »
Did you check the tech pages for the manuals on your truck?
Offline LTZ C20
« Reply #2 on: January 27, 2015, 02:08:44 pm »
The red circle in pic 1 looks like it might attach to the top yellow circle in pic 2.
The middle yellow circle in pic 2 should have a metal pipe going to the orange circle in pic 3.
The bottom yellow circle in pic 2 looks like it might go to the blue circle in pic 4.
« Last Edit: January 27, 2015, 02:10:38 pm by LTZ C20 »
LTZ Cheyenne C20
Offline LTZ C20
« Reply #3 on: January 27, 2015, 02:10:00 pm »
Check your manual like Capt. Said but if that's the only stuff disconnected then that should fix your problem.
LTZ Cheyenne C20
« Reply #4 on: January 27, 2015, 04:59:39 pm »
Thanks guys, there is alot of stuff that had been removed, I was able to get it to pass but wonder if i need to search through a junk yard to get the parts. Do you think its worth searching or should i just leave it ?
Offline LTZ C20
« Reply #5 on: January 27, 2015, 07:38:48 pm »
Depends. If you want it all original and/or to have everything working properly mechanically then it's worth searching. If you don't care and it runs good then worry bout it later or not all.
LTZ Cheyenne C20
Offline Tjerica1201
« Reply #6 on: February 05, 2015, 10:04:38 am »
http://www.73-87chevytrucks.com/techinfo/7387CKMans//Service/X8632_1986_GMC_Light_Duty_Truck_CK_G_P_10_to_30_Service_Manual.pdf
click through this.  Im sure it will outline all that info for you.  Its for an 86, but I don't think things changed all that much between 84 and 86.
« Reply #7 on: February 06, 2015, 06:16:39 am »
think #3 might be for run wires safety around edges. i have one on my 91 but its around the transmission bell housing and its bolted on.
