Lets play the guessing game
Topic: Lets play the guessing game (Read 5937 times)
traumajunkie
January 27, 2015, 11:50:56 am »
Ok I just recently bought a 1984 c10 with a straight 6, I went to do the nc safety inspection and failed because of some missing hoses, i cant tell by looking at the emissions paper where they go...
911 Please State Your Emergency
Re: Lets play the guessing game
January 27, 2015, 01:14:24 pm »
Did you check the tech pages for the manuals on your truck?
LTZ C20
January 27, 2015, 02:08:44 pm »
The red circle in pic 1 looks like it might attach to the top yellow circle in pic 2.
The middle yellow circle in pic 2 should have a metal pipe going to the orange circle in pic 3.
The bottom yellow circle in pic 2 looks like it might go to the blue circle in pic 4.
Last Edit: January 27, 2015, 02:10:38 pm by LTZ C20
LTZ Cheyenne C20
LTZ C20
January 27, 2015, 02:10:00 pm »
Check your manual like Capt. Said but if that's the only stuff disconnected then that should fix your problem.
LTZ Cheyenne C20
traumajunkie
January 27, 2015, 04:59:39 pm »
Thanks guys, there is alot of stuff that had been removed, I was able to get it to pass but wonder if i need to search through a junk yard to get the parts. Do you think its worth searching or should i just leave it ?
LTZ C20
January 27, 2015, 07:38:48 pm »
Depends. If you want it all original and/or to have everything working properly mechanically then it's worth searching. If you don't care and it runs good then worry bout it later or not all.
LTZ Cheyenne C20
Tjerica1201
February 05, 2015, 10:04:38 am »
http://www.73-87chevytrucks.com/techinfo/7387CKMans//Service/X8632_1986_GMC_Light_Duty_Truck_CK_G_P_10_to_30_Service_Manual.pdf
click through this. Im sure it will outline all that info for you. Its for an 86, but I don't think things changed all that much between 84 and 86.
February 06, 2015, 06:16:39 am »
think #3 might be for run wires safety around edges. i have one on my 91 but its around the transmission bell housing and its bolted on.
