Author Topic: 1986 C10 GU2 rear end  (Read 24094 times)
Offline swilliams
« on: February 01, 2015, 01:11:54 am »
I have the stock GU2 rear end in my 1986 C10. I need to find out if it has 28 or 30 spline axles. What i have found says it depends on the year but does not go any farther. Thanks
Offline Stewart G Griffin
Re: 1986 C10 GU2 rear end
« Reply #1 on: February 01, 2015, 10:13:40 am »
i think up to 87, the axles were 28. (77-87)  After 88 they went to 30.  But if you get a 30 spline carrier the 30 spline axles from later 10 bolts and 12 bolt trucks can fit.
This is according to Randy's differential book.
They are a top notch shop.  i would suggest calling them for help. :
 http://www.ringpinion.com/
Offline swilliams
« Reply #2 on: February 01, 2015, 01:40:44 pm »
Thanks for the help
« Reply #3 on: February 04, 2015, 05:17:07 pm »
The newer axles from a 88-up C/K 10 bolt are longer than 87 down R/V and C/K 10 bolts.
Offline swilliams
« Reply #4 on: February 04, 2015, 07:24:34 pm »
This is what i am looking at going with Detroit Locker 912A556 Detroit Truetrac Differential. It is for 28 spline axles. I want to be sure i  don't have 30 spline.
« Reply #5 on: February 05, 2015, 08:03:56 pm »
i'm sorry i meant the 12 bolt 30 spline axles which originally came in a 73-81 truck.
Offline swilliams
« Reply #6 on: February 06, 2015, 02:34:21 am »
Thanks for the help.
Offline 78BIG-TEN
« Reply #7 on: February 06, 2015, 09:19:04 am »
I used a True Trac and it crapped out in just over a year,worm gears inside gave up,but I think they might have upgraded these units.It was on a 89 k1500 with 33x10.50 tires.It made a horrific noise in tight turns
Offline swilliams
« Reply #8 on: February 06, 2015, 01:12:34 pm »
What would be a better choice?
« Reply #9 on: February 07, 2015, 09:37:40 am »
Some 12bolt 30 splines may require some massagine to get them to work, but yest they will go in.
As for a limited slip, it is going to come down to an individuals preference.
I used Eaton Clutch type LSD,  I know of people using the newer Truetrack without issues
What is the intended purpose?
Offline 78BIG-TEN
« Reply #10 on: February 07, 2015, 11:18:47 am »
I like the Eaton clutch type as well,that is what I replaced the True Trac with and some 7 years later still going,
« Reply #11 on: February 07, 2015, 08:39:58 pm »
No problem.
And i wonder if the 88-91 blazers and suburbans had the 30 spline axles?
Offline swilliams
« Reply #12 on: February 09, 2015, 09:45:18 pm »
My purpose is that since i have done some upgrades I spin the one tire. I am thinking that posi will help cut down on the tire spin.
« Reply #13 on: February 19, 2015, 11:37:19 pm »
Yes they did...
It could make it spin both, but it should help...
Offline Rich84
« Reply #14 on: February 23, 2015, 01:34:00 pm »
I used a 30spline carrier and axles out of an 88 and up truck in my 10 bolt..If I remember correctly the axles were about 3/8 of an inch longer. I had to go with a Buick Roadmaster drum to accommodate the longer axle.
