Author Topic: What Am I? (Alternator)  (Read 7640 times)
Offline enaberif
« on: February 04, 2015, 07:15:55 pm »
I am big and I am heavy. I measure 8" across the bolt holes from the center points. I do not seem to be a 10si nor do I seem to be a 12si. According to the clock position I am a 1 o'clock alternator not a normal 3 o'clock gm alternator. I have Delco Remy name branded on my case. Oh and I also do not fit properly with the alternator bracket.
Can you tell me who I am please.
Offline enaberif
Re: What Am I? (Alternator)
« Reply #2 on: February 04, 2015, 07:26:58 pm »
http://www.madelectrical.com/electricaltech/delcoremy.shtml
Yeah I read that page as well as read the page that has the dimensions of AC Delco alternators and nothing matches up.
Offline ehjorten
« Reply #3 on: February 05, 2015, 10:53:27 am »
Looks like a 27SI.  Your pictures do not show the mounting ears from the side,  but it looks to have 2 ears on the bottom mount.  The back one having a bushing in it.  The inside distance between the ears should be 2.60" and be 0.39" Diameter.
27SI has a high amp output at idle.  It is recommended for passenger car and light trucks when high output at idle is necessary.  There is a 100 A and an 80 A version.  The 80 A version has a special R-terminal for use with electric tachs and tach hour meters, etc.
The only Original to Service 27SI-100 part number that I could find is 1105500 (AC Delco Reman. #10459234 and AC Delco Catalog #321-744
There are 2 Original to Service 27SI-80 part numbers that I could find: 1101058 and 1101061 (Delco Remy Reman. #'s: 19020504 and 19020504, respectively)
« Last Edit: February 05, 2015, 10:59:24 am by ehjorten »
-Erik-
Offline Shifty
  • I bleed Bowtie red...
« Reply #4 on: February 05, 2015, 11:33:21 am »
It looks like a Lester (industry p/n) 7135.
98 C2500 ext cab longbed
Offline enaberif
« Reply #5 on: February 05, 2015, 12:53:20 pm »
Thanks guys definitely looks like a 27si alternator!
Offline enaberif
« Reply #7 on: February 05, 2015, 01:25:14 pm »
Well crap if this thing is a 100a alternator I may just keep using it. Guess I'll get it tested to see what happens!
« Reply #8 on: February 05, 2015, 01:36:02 pm »
They made 80 amp versions also
Offline enaberif
« Reply #9 on: February 05, 2015, 01:37:09 pm »
Yeah I'll take it in and get it tested.
