Author Topic: OEM Clearance/Roof Lights  (Read 24864 times)
Offline IdahoMan
« on: February 06, 2015, 09:32:16 pm »
My roof light lenses are getting cracked and I need some replacements.
Are there any OEM out there, or any very good aftermarket?
Thanks.
IM
Re: OEM Clearance/Roof Lights
« Reply #1 on: February 06, 2015, 11:03:56 pm »
have you checked ebay
« Reply #2 on: February 07, 2015, 09:20:54 am »
Recon makes some low profile ones
See here for comparison: http://forum.73-87chevytrucks.com/smforum/index.php?topic=7921.msg50309#msg50309
Offline IdahoMan
« Reply #3 on: February 07, 2015, 01:11:17 pm »
Thanks Captkaos.
I like the low-profile, but I'd have to drill new holes and do something with old ones.
Offline LTZ C20
« Reply #4 on: February 07, 2015, 01:39:17 pm »
You could always replace the factory ones and just put the small LED bulbs in. That's what I'm gonna do with mine.
LTZ Cheyenne C20
Offline Engineer
« Reply #5 on: February 07, 2015, 06:47:47 pm »
OEM lens you say? GM P/N 684662 (old part number maybe discontinued).
However all is not lost.......
Truck-Lite 9069A is the actual GM OEM lens available through the aftermarket.
Truck-Lite 1313A is the actual GM OEM lens, and rubber base also available through non-GM sources.
I have several nos rubber bases in the GM bags that I am holding onto in case the brand new ones I just put on my '77 ever dry out. I also have brand new lenses (bought while GM still had them) that aren't all frosty.  ;D
« Last Edit: February 07, 2015, 06:49:21 pm by Engineer »
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline Engineer
« Reply #7 on: February 07, 2015, 07:05:40 pm »
Thank you for the info and link.  I want to add that to my C20 when I get it done.  I just have to harvest a wiring loom and find a truck to measure for placement.  I knew I should have measured it before I sold it.
Offline LTZ C20
« Reply #8 on: February 07, 2015, 08:38:02 pm »
Zieg, I added cab lights to my C20  that didn't originally have them. I have all of the factory measurements if you would like them. They are actually measurements on top of a pic of a roof so you can see EXACTLY where to place them.
As for sourcing a wiring harness, I know Chris doesn't have them unfortunately, but a competitor has them for $14.95.
« Last Edit: February 07, 2015, 10:38:10 pm by Irish_Alley »
LTZ Cheyenne C20
« Reply #9 on: February 07, 2015, 09:05:46 pm »
As for sourcing a wiring harness, I know Chris doesn't have them unfortunately, but one of the major resto parts suppliers ending in "truck" has them, $14.95.
Awesome, I will PM you my email address.  Thanks
Offline LTZ C20
« Reply #10 on: February 07, 2015, 09:10:06 pm »
Ok. Your welcome.
LTZ Cheyenne C20
Offline IdahoMan
« Reply #13 on: February 08, 2015, 03:07:37 pm »
here some led ones with the wires
http://www.ebay.com/itm/Set-5-Cab-clearance-1313A-Amber-Light-10-5730-SMD-194-bright-Amber-LED-for-Chevy-/181660029304?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2047675.l2557&nma=true&si=YbB%252FNqfC0trpiKars%252BogUA8BpO8%253D&orig_cvip=true&rt=nc
I have that seller in my watching.  I am really wanting OEM bases and OEM wiring loom.  They seem to offer 3 different brightness LED's probably go for the middle one if I choose anything.  I will be on the hunt for OEM first
« Reply #14 on: February 08, 2015, 03:25:34 pm »
im wanting my truck to light up light a Christmas tree when i get done with her. prob get the running boards that have lights in them also
