Author Topic: Bench Seat Removal..  (Read 20085 times)
Offline IdahoMan
« on: February 07, 2015, 12:43:05 pm »
Just unscrew the 4 bolts (two on each side) and walk the seat out through the passenger-side door right?
Any pointers though before I proceed? Things I need to keep in mind?
Also, is there a safe known way of driving without the seat installed, like with a table/picnick chair? (sound funny, but who knows)
IM
Offline Shifty
  • I bleed Bowtie red...
Re: Bench Seat Removal..
« Reply #1 on: February 07, 2015, 12:56:27 pm »
Just the 4 bolts...you may have to watch the seatbelts, depending on your year, but definitely watch your back.  It's not really that heavy, but it's and awkward lift.
98 C2500 ext cab longbed
Offline LTZ C20
« Reply #2 on: February 07, 2015, 01:40:08 pm »
Helps if you got 2 people. 1 will pick up one side and walk backward with the seat, the other will pick it up and have to "walk" or move thru the cab from one side out the other. Like pick up on drivers side and come out on passenger side like you said.
« Last Edit: February 07, 2015, 01:42:00 pm by LTZ C20 »
LTZ Cheyenne C20
Offline srozell
    • My 1980 Chevy
« Reply #3 on: February 07, 2015, 09:06:20 pm »
I just did that with my son. It came out the driver's side easy enough too.
1980 K20 "Camper Special"
1969 K20 Step Side
http://myuglytruck.wordpress.com/
Offline rich weyand
« Reply #4 on: February 08, 2015, 09:17:52 am »
It's been several years, but as I recall it makes it easier if you fold the seat back down.
« Reply #5 on: February 08, 2015, 09:23:23 am »
If you have a piece of 1/4" hardboard it makes the job easier.  I always undo the 2 rear first.  Then move the seat all the way back to remove the front 2.  Then I get the belts through the seat bottom and free.  I then put the hardboard under the drivers side rail, tilt the seat forward and slide out the passenger side.  I never have help when I need it so I've learned to do a lot on my own including removing a cab...
Offline LTZ C20
« Reply #6 on: February 08, 2015, 10:52:31 am »
Good idea zieg. I once moved my extra long bed chassis from a trailer to my backyard with nothin but a really long chain and a tractor, no help needed lol. That was a site to see...
LTZ Cheyenne C20
