Author Topic: Steering column change 87 2wd 3/4 ton  (Read 3976 times)
Offline NCali
« on: February 09, 2015, 09:17:28 pm »
Bil wrecked his steering column so he went to a local wrecking yard , couldnt find a truck with a good column but he saw an 87 caprice that he said looked like the same column: tilt,same turn sig switch with cruze
Will it fit?   I dont think that a blazer column is the same so I doubt a pass car column would fit
any thoughts?
Black Labs Matter
Offline roundhouse
Re: Steering column change 87 2wd 3/4 ton
« Reply #1 on: February 10, 2015, 10:15:55 pm »
I'd think a blazer colum is the same
« Reply #2 on: February 11, 2015, 12:10:07 am »
they may look the same caprice vs truck (the steering column housings are the same) but i doubt they are the same length
« Last Edit: February 11, 2015, 12:31:12 am by Irish_Alley »
« Reply #3 on: February 11, 2015, 12:22:29 am »
Full sized Blazer 84-91 will work in your 1987 C20
