Author Topic: 80's three door conversion???  (Read 13279 times)
Offline ca180
« on: February 21, 2015, 05:57:27 pm »
Does anyone have info on a company that created a three door conversion from a long bed C10?
Re: 80's three door conversion???
« Reply #1 on: February 21, 2015, 05:59:57 pm »
almost want to say it looks like someone took a crew cab and swapped the rear doors to make it a "suicide" door. never seen that before
Offline ca180
« Reply #2 on: February 21, 2015, 06:01:09 pm »
That's what I thought, too. I'm just curious if there was any other info on it. Like, maybe a company that did conversions? It looks interesting, but I'm concerned about it possible being a hack job with TONS of bondo...
Offline LTZ C20
« Reply #3 on: February 21, 2015, 06:01:22 pm »
It kinda looks like the conversion extended cabs that a company in texas used to build. But they never did any with doors that I know of. First extended cab with a working door that I've ever seen.
LTZ Cheyenne C20
Offline ca180
« Reply #4 on: February 21, 2015, 06:04:50 pm »
I kind of wonder if it was a typo and that it's a 4 door with a suicide conversion... Hmmmmm....
« Reply #5 on: February 21, 2015, 06:05:32 pm »
i dont see a conversion company taking the time to stretch a regular cab for the size of a crew cab. to me it looks like a crew cab read door
Offline ca180
« Reply #6 on: February 21, 2015, 06:13:22 pm »
Just called the guy... Apparently it was a custom job with 3 doors! And apparently the rear seat would slide down in to a bed. Unfortunately, he traded it already to someone else. Interesting none the less!
Offline LTZ C20
« Reply #7 on: February 21, 2015, 07:03:44 pm »
Irish, neither do I. Infact it does look like it probably WAS a crew cab rear door, but it's about 1/2 - 3/4 the size of a crew rear door. Also, it's probably the RIGHT rear stuffed onto the left side, the door handle is in the wrong place and the edge that meets the front door doesn't match the contour of a left rear door. It looks like there might be a lock cylinder in the middle of the yellow stripe too.
LTZ Cheyenne C20
« Reply #8 on: February 21, 2015, 07:16:48 pm »
i have heard of a conversion for the crew cabs. this conversion involves making them crew+ extended cab so you can put the fold down bench in the rear. would love to see better/more pictures. also the bed has been cut down also
« Reply #9 on: February 21, 2015, 07:24:04 pm »
i do see the lock cylinder in the rear door. but not one in the front? also i think i only see 5 lugs up front for a ½ ton
« Last Edit: February 21, 2015, 07:26:13 pm by Irish_Alley »
Offline LTZ C20
« Reply #10 on: February 21, 2015, 07:57:16 pm »
So like a 6 door cab, 4 full size doors and 2 half size doors?
Saw the bed and no cylinder in drivers door and the lug nut count. Good eyes.
LTZ Cheyenne C20
« Reply #11 on: February 21, 2015, 10:31:16 pm »
nope, 4 door with the extended cab added on no doors like ziegs truck but will 2 more doors before the side rear window
Offline LTZ C20
« Reply #12 on: February 22, 2015, 12:22:28 am »
Oh ok. So you get 2 full size front doors, then 2 half size extended cab doors, then just a extended cab no doors before the bed.
LTZ Cheyenne C20
« Reply #13 on: February 22, 2015, 12:27:02 am »
Offline LTZ C20
« Reply #14 on: February 22, 2015, 12:36:26 am »
Oh whoa, wow. Nice.
LTZ Cheyenne C20
