Author Topic: 86 long bed, 2 inch shackles hitting bed!!!! what the heck did I do?????????  (Read 7657 times)
Offline chippy
First post!!!! Hello all..
I have an 86 long bed 2WD. I simply wanted to lower the rear 2 inches to level her out. The swap went fine, but when I took her off the jacks the new shackles rest on the bed.
Talk about disappointed  in my skills.. Here is a picture of the finished product.  I looked close at the new ones and it didnt appear to be a front or back, no significant bend or bow in the shackle so I dont think they are on backwards.
Any help will be appreciated. Chip
Offline blueboy86
I have read on this before but not 100% sure. You are going to have to c notch the bed support it is hitting. Hand grinder with cutting wheel should do it.
Offline FlatBlack77
ive always read the same thing. there needs to be a small notch in the bed supports
Offline blueboy86
Here's a picture I found.
What length spring do you have? The shackle should be behind the wheel house
Offline chippy
How do I measure the springs?
Offline 78BIG-TEN
I had the same problem with those on my 78.I didn't want to notch the bed so I used the lower hole on the shackle and cleanced it for the spring,then cut the top off the shackle .But youl raise it up about a half inch or so
Offline MaxmillianS
On my 80 short bed i had to notch out the bed as well, it said in the instructions for the kit I bought.
