Author Topic: Gaskets  (Read 4763 times)
Offline traumajunkie
Gaskets
« on: February 24, 2015, 06:15:17 pm »
Hey guys, i have attempted to replace the  push rod cover gaskets with the cork by fel pro on my 84 c10 4.1. I installed then like the parts store said ( blk silicone on the side facing the cover )and put it back together i started her up and noticed a little oil leaking around the corners so i tightened it up and it seam to stop. (Oil pressure gauge read about 30, i dont know what it should read!! So if you know please share) after warm up i drove down the road and saw it dropped to 25psi. I pulled over and looked under the hood and oil was flowing out from the gasket. By the time i go home it was 20psi. What did i do wrong and did i damage my engine?
911 Please State Your Emergency
Offline enaberif
Re: Gaskets
« Reply #1 on: February 24, 2015, 06:40:51 pm »
Fel-Pro blue one piece gaskets and ensure your valve covers are flat. Then get spreader bars to help.
Offline Engineer
Re: Gaskets
« Reply #2 on: February 24, 2015, 06:42:47 pm »
Did you do anything to block the oil drain back holes in the head? Drop any old chunks of gasket down inside the head?
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline jetmech
Re: Gaskets
« Reply #3 on: February 24, 2015, 06:55:15 pm »
Only thing I see is perhaps the gaskets were able to slide out of their place with the silicone. I like to use brush on Copper Coat on the really clean covers and let it get almost dry before sticking the gasket in place. I doubt your engine was hurt if you were driving normally and didn't run it completely out of oil. Not sure what pressure is normal for a six banger but would guess that 25 with engine warm and freeway speed would be ok, 30-35 would be better.
'86 Sub and '86 SWB C-10
1990 454 SS
Re: Gaskets
« Reply #4 on: February 24, 2015, 07:17:17 pm »
Thank you for the reply, I did the side covers So dont think anything fell in them.. I am thinking of trying to find a rubber gasket if they exist, the cork was kida tights around the covers.. Was i suppose to silicone it to the motor as well?
Offline Jason S
Re: Gaskets
« Reply #5 on: February 24, 2015, 09:14:26 pm »
On I-6 tappet cover gaskets (side cover), I've had the best success with Permatex #2 on both sides of a cork gasket. Of course, ensure the cover and block are thoroughly clean before applying the gasket.
Offline rich weyand
Re: Gaskets
« Reply #6 on: February 24, 2015, 10:43:22 pm »
Use this stuff to seal gaskets.  Clean gasket and mating surfaces with lacquer thinner.  Rub TiteSeal into both sides of gasket and both mating surfaces, leaving a very thin coating.  Assemble.  End of problem.
http://www.skygeek.com/gunk-t25-66-1lb-gunk-t2566-tite-seal-gasket-joint-sealing-compound-medium-weight-1-lb-tin.html
Re: Gaskets
« Reply #7 on: February 25, 2015, 07:37:14 am »
Thank you guys I will re do this hopefully before the snow comes
