Members Rides
Getting a little fancy... 1987 V10
6
7
8
9
18
Topic: Getting a little fancy... 1987 V10 (Read 211662 times)
LTZ C20
Re: Getting a little fancy... 1987 V10
Reply #90 on:
September 22, 2015, 01:36:37 pm »
That works
LTZ Cheyenne C20
frotosride
Reply #91 on:
September 27, 2015, 09:02:11 pm »
How about HID's... just in the low beams for now. Got these for free and the we're brans new from a friend so I figured what the heck. A little trimming to the plastic around the bulb and they fit with a perfect seal that came with he kit.
Last Edit: September 30, 2015, 02:24:23 pm by frotosride
LTZ C20
Reply #92 on:
September 28, 2015, 01:02:05 am »
Ok now your just showing off haha
LTZ Cheyenne C20
frotosride
Reply #93 on:
September 30, 2015, 02:23:06 pm »
LTZ C20
Reply #94 on:
September 30, 2015, 08:50:44 pm »
Looks good! Wait till I get those lights I mentioned in my post "Modest not Outrageous Headlight Upgrade". I'll really brighten your day lol, pun intended.
LTZ Cheyenne C20
frotosride
Reply #95 on:
February 08, 2016, 09:00:12 pm »
Well its been a while, a small change in venue, most of the 'honey do' list is. Complete and now its time to make that runstand earn its keep. No that it hasn't already by simply holding the engine for almost a year since I only have a small roll of wire invested in to it. I'm gonna post a few pics of updates that I've accomplished over the last week all in the name of just getting the engine running to see that my wiring paid off before I strip the engine down and replace bearings and gaskets if need be. Bearings are gonna be a definite though.
frotosride
Reply #96 on:
February 08, 2016, 09:12:52 pm »
My youngest son and I did a little cleaning and prep. He removed all the could packs and we found the tip to number 1 cylinder broke. It's just the insulator that is broke so hopefully with the wire shroud in it there won't be any scatter to the valve cover.
I just finished modifying the old sending unit to accept -6 an fittings and line. I also got the filler pipe and valve welder to the prelube tank yesterday. I'm going to mock up the fuel system in a bucket to test the crap looking hose clamps that came with the pump. Then exhaust gaskets, prelube and fire up. I will get a video of start up until edited so if there 8s a problem maybe it will help someone else to not make the same mistake.
frotosride
Reply #97 on:
February 09, 2016, 06:12:32 pm »
Got fuel system set up. This is the exact system that will run in the truck plus another tank. The 'T' fitting has an 1/8" port for a Guage fitting that's almost worthless. The plug sits so low in the 'T' fitting that it's sure to block flow and if you use a standard fitting it will almost completely block flow soo...
I modified it!
frotosride
Reply #98 on:
February 10, 2016, 04:07:19 pm »
Tested the fuel system today. First and second test were fails due the 'T' fitting Guage port.
Once I figured out that it wasn't the hoses leaking on the 'T' fitting I just took it out and bam...it's good to go!
LTZ C20
Reply #99 on:
February 10, 2016, 10:29:32 pm »
Your picks are small and fuzzy.
LTZ Cheyenne C20
Reply #100 on:
February 11, 2016, 07:22:25 am »
cause theyre vids lol
frotosride
Reply #101 on:
February 11, 2016, 11:56:14 am »
Or you could call them picture shows...
Reply #102 on:
February 11, 2016, 12:24:53 pm »
picture shows with sound
frotosride
Reply #103 on:
February 12, 2016, 02:25:51 pm »
Once LTZ figures those out he's gonna love the next one. It should have a lot of sound now that my prelube tank is complete with oil filter and an air filter that has desiccant inside. I also got my Jegs order in less than 48 hours and it was on my door step! Can't beat that!
LTZ C20
Reply #104 on:
February 14, 2016, 05:05:14 pm »
Well they aren't playing for some reason. Videos on here usually show up the same size as pics and work. These are real small and really fuzzy and definitely aren't videos. Upload issue?
LTZ Cheyenne C20
6
7
8
9
18
Members Rides
