Author Topic: Getting a motor running  (Read 8294 times)
Offline gutts
« on: February 24, 2015, 09:30:23 pm »
Hello
  I have been looking for a new used motor for a v10 pickup . A person I do not know has a 87 blazer that has been sitting a little while , not very long . He has stated that the thing needs transmission and brake lines . I know this a common problem , in the "rust belt .
   The rub is it needs fuel pump also . Is there a way to get this thing running , for a few minutes , just to hear the motor run ?
Offline roundhouse
Re: Getting a motor running
« Reply #1 on: February 24, 2015, 10:25:47 pm »
Low psi Electric fuel pump drawing from small gas can
Make sure to have fire ext on hand just in case of a problem
Offline gutts
« Reply #2 on: February 24, 2015, 10:51:04 pm »
Like an old fashioned ones from the sixties ?
    Thank you
Offline gutts
« Reply #3 on: February 24, 2015, 10:56:14 pm »
What should the PSI be ?
   4-6 ?
     9
   I appreciate the information.
« Reply #4 on: February 24, 2015, 11:00:18 pm »
depends, a tbi likes 18psi if you tap into the existing fuel supply line and run a correct pump with the right psi the ecm will take over. if you dont have the right pump you might run lean or the engine might not run at all
Offline gutts
« Reply #5 on: February 25, 2015, 05:54:22 am »
Yes I understand . It is a TBI . I  should look for a 18 PSI pump .
    We have two feet of snow here so , no hurry , just trying to think ahead a bit .
        Thank you
« Reply #6 on: February 25, 2015, 06:32:32 am »
also if you can run a hot wire from the battery to the fuel pump relay, theres a 4" red wire with a female spade connection on it. if you give that wire 12v you will bypass the relay and power the pump directly and you might luck out and the pump might just start up
Offline gutts
« Reply #7 on: February 25, 2015, 03:45:17 pm »
Alright that great info . I will find the relay on my truck and look it over so , when I go to look at this one , I will know just where it is . Is it common for the relays to fail ?
« Reply #8 on: February 25, 2015, 05:30:31 pm »
I wouldn't say common but can happen. Sometimes they don't get energized by the ecm due to other problems. But its real easy to bypass so might as well try
Offline fitz
« Reply #9 on: February 27, 2015, 03:48:41 am »
If you just want to fire it up to see if it knocks, give it a shot of starting fluid.
« Reply #10 on: February 27, 2015, 11:17:49 pm »
some only knock once theyre up to temp
Offline gutts
« Reply #11 on: March 01, 2015, 09:33:20 pm »
Thank you all
  Really appreciate the info .
« Reply #12 on: March 03, 2015, 06:43:30 am »
A spray bottle with gas in it. Have someone crank it while you mist it. Have run many motors this way. Have run a motor a few times by putting a rag over part of the carb or TBI soak it with gas, it will run for a minute or two, longer if you keep the rag wet.
« Last Edit: March 03, 2015, 06:45:23 am by Blazin »
Offline roundhouse
« Reply #13 on: March 03, 2015, 09:42:58 am »
Just keep a fire extinguisher handy
Offline gutts
« Reply #14 on: March 05, 2015, 08:04:53 pm »
 Yes , I was thinking spray bottle and FE TOO . SOUNDS BETTER THAN STARTING FLUID .
 THANKS
