Author Topic: How to Remove/Install an sm465 muncie transmission and np208 transfer case  (Read 9641 times)
Offline moneyg77
I need to R&R my transmission and transfer case but I have no clue how to do it. I can't seem to find any step by step instructions on youtube or through the forums. Can someone help? Thanks I advance. I'm sure this will help people in the future.
1981 K-10 longbed stepside 350/465/208/quadrajet. 6"lift, 35" BFG, custom exhaust
1983 K-10 swb 4"lift
1986 lwb fleetside
Offline roundhouse
Re: How to Remove/Install an sm465 muncie transmission and np208 transfer case
« Reply #1 on: February 25, 2015, 09:11:38 pm »
You'll need a transmission jack
I remove the t case seperatly just because it's so heavy
Then pull one boot from the trans to bell housing
Go buy 4 new ones just like it but 3" longer
Saw off the head and use a hacksaw to cut a screwdriver slot where the head used to be
Replace the factory bolts one at a time wih these  new
Ones
THat way when you slide the trans back these bolts will support the weight
Makes it a lot easier to re install because you have to hold the trans up and turn the output shaft a little to line up the splines into the clutch disc
Offline moneyg77
« Reply #2 on: February 25, 2015, 11:28:45 pm »
I'm just trying to wrap my head around this. You recommend that I buy 4 longer bolts and then cut off the bolt head and replace with a screwdriver slot...why can't I just buy the longer bolts and leave the bolt head there? I'm just trying to understand the concept
1986 lwb fleetside
Offline enaberif
« Reply #3 on: February 25, 2015, 11:56:24 pm »
The bolts act as dowels with the head on them you can't put the bell housing on.
Offline roundhouse
« Reply #4 on: February 26, 2015, 07:16:54 am »
Bolting the bell back on the engine is pretty easy since it has dowels
Bolting the trans to the bell is not easy
The headless bolts will support the 200 lb weight of the transmission while you get the input shaft splines lined up and inserted into the clutch disc
There's probably some how to vids on YouTube
Drain the oil from the t case and trans before you remove  them
And you will need a helper
The trans alone weighs 150 lbs I think
T case is 110 or so
« Last Edit: February 26, 2015, 07:19:38 am by roundhouse »
