Author Topic: What year is my chassis?  (Read 4016 times)
Offline joebino55
« on: March 20, 2015, 07:05:29 pm »
So I recently bought a Chevy K20.  Well the cab is an 82 but the frame/chassis/drivetrain are not.  I looked up the casting number on the engine block and its a 75.  I assume the rest of the truck is similar year but I'm not 100% sure.  The rear axle is a corporate 10.5" 14 bolt and the front axle is a Dana 44 with big hubs that bolt on. Transmission is SM465 with a 205 transfer case.
Anybody know sure way to tell what year my frame is?
I guess what I am getting to is that I want to remove the aftermarket 6" lift springs that are on it and go with stock springs and need to know what year I have when looking for springs.
Thanks for any help.  I can post pictures as soon as I figure it out.
Re: What year is my chassis?
« Reply #1 on: March 20, 2015, 07:07:13 pm »
If you think it's around a 75, look on top of the frame rail next to the steering box. Scrape it down good and read the vin #
Offline Engineer
« Reply #2 on: March 22, 2015, 07:13:06 pm »
All 73~87(91) 4x4s used the same front spring mount dimensions.
Only difference is the capacity and they'll all interchange.
Choose the ones you want and order away. Don't worry about year.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
